Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
    Junior Member
    AutoCAD 2013
    Jan 2013
    20
    Default Getstring & Strcat
    Hi,
    I'm trying to write a lisp to help me do the elevation leader & material code easier.
    But seems like I miss understand some function.
    I want to setq the Material Code by only input 2 digit, for example, "1" + "3" should return WC03. But right now !Material return 1, !Code return 3..... and !MaterialCode return MaterialCode......
    (setq Material (getstring "\nSpecify material [1_WC/2_WD/3_ST/]: "))
    (setq Code (getstring "\nSpecify material [1_01/2_02/3_03/4_04]: "))
    (setq MaterialCode (strcat "Material" "Num"))
    Junior Member
    AutoCAD 2013
    Jan 2013
    20
    Hey Guys,
    I just help myself out, i should use getkword and it should look like below
    (setq Mat1 (getkword "\n [BL/CP/GL/FA/FB/ML/P/PL/SP/ST/TL/WC/WD]<ML>: "))
    (initget "01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20")
    (setq Num1 (getkword "\n [01/02/03/04/05/06/07/08/09/10/11/12/13/14/15/16/17/18/19/20]: "))
    (setq Mat1Num1 (strcat Mat1 Num1))
    And then get what i want
    But to make it more friendly, how do type 1=01 without the clarify window asking which number has1 ?
    Super Member hanhphuc's Avatar
    AutoCAD 2007
    Apr 2013
    Happy Garden
    657
    hi please use code tag
    Quote Originally Posted by leong1221 View Post
    This code with code tags
    Code:
    (defun matNum (/ l i s mat1 Num1)
      (setq	i 1
    	l '("BL" "CP" "GL" "FA"	"FB" "ML" "P" "PL" "SP"	"ST" "TL" "WC"
    	    "WD")
      (repeat (length l)
        (setq s (cons (strcat (itoa i) "_" (nth (1- i) l) " / ") s))
        (setq i (1+ i))
      (initget 7)
      (if
        (and
          (setq i (getint (strcat "\nIndex number ["
    			      (apply 'strcat (reverse s))
          (<= i (length l))
          (setq mat1 (nth (1- i) l))
    	(initget 7)
    	(setq i (getint "Enter number 1~20 ? : "))
    	(setq Num1 (itoa i))
    	(<= i 20)
      (princ (strcat Mat1
    		 (if (< i 10)
    		   (strcat "0" Num1)
    		   Num1
      (prompt "\nInvalid Input.. ")
    ;(princ) ; removed
    _$ ( apply 'equal "hp" "happy" "hạnh phúc" "ハッピー" "幸福" "행복" )
    ; error: too many arguments
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,511
    Ths may be useful we want D01-d09 then D10+ taken from some code.
    Code:
    ; if less than 10
        (if (< (car dwgnum) 10.0)
          (setq newstr2 (strcat dwgname "-D0"  (rtos sheetnum 2 0)))
          (setq newstr2 (strcat dwgname "-D"  (rtos sheetnum 2 0)))
  5. #5
    Junior Member
    AutoCAD 2013
    Jan 2013
    20
    Hi hanhphuc,
    Thanks! It works perfectly!
  6. #6
    Junior Member
    AutoCAD 2013
    Jan 2013
    20
    Quote Originally Posted by hanhphuc View Post
    Code:
    (defun c:test (/ l i s mat1 Num1)
      (setq	i 1
    	    "WD")
      (repeat (length l)
        (setq i (1+ i))
      (initget 7)
      (if
        (and
          (<= i (length l))
    	(initget 7)
    	(<= i 20)
      (princ (strcat Mat1
    		 (if (< i 10)
    		   (strcat "0" Num1)
    		   Num1
      (princ "\nInvalid Input.. ")
    The reason I setq Mat1 and Num1 is to help -insert an attribute block in next step and to rename the block according to what just input, for example by running your lisp and input "1" "1" then i got an attribute block named BL01.
    Any hint how to do it? Many thanks
  7. #7
    Junior Member
    AutoCAD 2013
    Jan 2013
    20
    I was think the command Gatte, and then I write it to my lisp
    (command "gatte") and return GATTE Unknown command "GATTE"
  8. #8
    Senior Member
    Civil
    Aftertouch's Discipline Details
    Civil
    Engineer
    AutoCAD 2017
    Jul 2016
    Netherlands
    287
    GATTE is a Global Attribute Edit function.
    If you want to rename the block, i would just 'insert' the regular block, and use a RENAME function on the ENTLAST?
  9. #9
    Junior Member
    AutoCAD 2013
    Jan 2013
    20
    Quote Originally Posted by Aftertouch View Post
    Hi, i attached an image to clarify me idea
    Thanks
    Leo
  10. #10
    Junior Member
    AutoCAD 2013
    Jan 2013
    20
    Thanks
    Leo
    Step1 is done, stuck at step 2
  1. strcat help sought
    By diarmuid in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th Dec 2017, 08:58 am
  2. Need some help with getstring
    By pmxcad in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Nov 2017, 08:21 pm
  3. Getstring Question
    By harrison-matt in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Oct 2010, 10:57 pm
  4. problem with strcat
    By Sweety in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Aug 2010, 08:39 pm
  5. getstring
    By jay3791 in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Sep 2009, 07:21 pm
