+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
  1. #11
    Junior Member
    Using
    AutoCAD 2013
    Join Date
    Jan 2013
    Posts
    20
    Default
    I found below lisp by SMadsen which is what I close except it changes tag in all block
    Credit: SMadsen
    https://www.theswamp.org/index.php?topic=5917.0
    (defun changeAttribValue (ent atttag oldval newval / entl)
    (while (and ent (/= "SEQEND" (cdr (assoc 0 (setq entl (entget ent))))))
    (and (= atttag (cdr (assoc 2 entl)))
    (= oldval (cdr (assoc 1 entl))) ;<- could use WCMATCH instead
    (entmod (subst (cons 1 newval) (assoc 1 entl) entl))
    (entupd ent)
    (mapcar 'princ (list "\n" oldval " -> " newval))
    (setq ent (entnext ent))
    (defun C:CHATTRIB (/ ss a attag bname oldval newval)
    (and (/= "" (setq bname (getstring "\nBlock name: ")))
    (/= "" (setq attag (getstring T "\nTag: ")))
    (/= "" (setq oldval (getstring T "\nOld value: ")))
    (/= "" (setq newval (getstring T "\nNew value: ")))
    (setq a 0
    ss (ssget "X" (list '(0 . "INSERT") '(66 . 1) (cons 2 bname)))
    (repeat (sslength ss)
    (changeAttribValue (ssname ss a) attag oldval newval)
    (setq a (1+ a))
  2. #12
    Senior Member
    Discipline
    Civil
    Aftertouch's Discipline Details
    Discipline
    Civil
    Details
    Engineer
    Using
    AutoCAD 2017
    Join Date
    Jul 2016
    Location
    Netherlands
    Posts
    303
    Default
    Do you want to set the values before or after you place the block?
    If you want to set the values before you place the blocks the code could look like...
    Code:
    (command "_insert" "<BLOCKNAME>" l "1" "1" "" <ATTRIBUTE1> <ATTRIBUTE2>)
    And you could define the attributes before you place the block.
    set attribute1 with your Kword method.
    set attribute with a cond function, wich evaluates the first attribute...
    If you want to be able to change the attributes when the block is already placed, you might be able to use Lee Mac's functions below...
    Code:
    ;; Set Attribute Value  -  Lee Mac
    ;; Sets the value of the first attribute with the given tag found within the block, if present.
    ;; blk - [ent] Block (Insert) Entity Name
    ;; tag - [str] Attribute TagString
    ;; val - [str] Attribute Value
    ;; Returns: [str] Attribute value if successful, else nil.
    (defun LM:setattributevalue ( blk tag val / enx )
        (if (and (setq blk (entnext blk)) (= "ATTRIB" (cdr (assoc 0 (setq enx (entget blk))))))
            (if (= (strcase tag) (strcase (cdr (assoc 2 enx))))
                (if (entmod (subst (cons 1 val) (assoc 1 (reverse enx)) enx))
                        (entupd blk)
                        val
                (LM:setattributevalue blk tag val)
    First click the block,
    Ask KWORD for first value
    COND the KWORD for the second value.
    Use above function twice to set the values?
  3. #13
    Computer Details
    SLW210's Computer Details
    Operating System:
    Windows 7 PRO 64-bit
    Computer:
    IBM Lenovo
    Motherboard:
    ACPI x64
    CPU:
    Pentium(R) i5 4570 @ 3.2GHz
    RAM:
    8 GB RAM
    Graphics:
    Nvidia Quadro 600 1GB
    Primary Storage:
    300 GB
    Secondary Storage:
    650GB
    Monitor:
    2x ThinkVision 24"
    Discipline
    Multi-disciplinary
    SLW210's Discipline Details
    Occupation
    Design Draftsman
    Discipline
    Multi-disciplinary
    Details
    Using
    AutoCAD 2018
    Join Date
    May 2007
    Location
    South Florida, USA
    Posts
    12,128
    Default
    Please read the Code Posting Guidelines and edit your Code to be included in Code Tags.[CODE]Your Code Here[/CODE] =
    Code:
    Your Code Here
  4. #14
    Super Member hanhphuc's Avatar
    Using
    AutoCAD 2007
    Join Date
    Apr 2013
    Location
    Happy Garden
    Posts
    749
    Default
    my suggestion if you have many options to select, activate the dynamic input
    Code:
    (setvar 'dynmode 1)
    then you are able to click the value (acts like a radio button in dcl)
    but remember restore it at the end of the code.
    if you insert more than 1 block, just call the defun
    see update in post#3
    example:
    Code:
    (if
    (and
    (setq Mat1Num1 (MatNum))
    (setq Mat2Num2 (MatNum))
    (setq p1 (getpoint "\nSpecify point1 : "))
    (setq p2 (getpoint "\nSpecify point2 : "))
    (command "-insert" Mat1Num1 p1 1 1 0 ) ; do something
    (command "-insert" Mat2Num2 p2 1 1 0 ) ; do something else
    p/s: please don't ignore the moderator's advice to edit your previous post with code tags
    _$ ( apply 'equal "hp" "happy" "hạnh phúc" "ハッピー" "幸福" "행복" )
    ; error: too many arguments
  5. #15
    Junior Member
    Using
    AutoCAD 2013
    Join Date
    Jan 2013
    Posts
    20
    Default
    Hi Hanhphnc,
    Thanks for helping me to get this far, I have merge together and the lisp seems almost working .
    Below lisp is my attempt of using command "-Attedit" to change the attribute block tags value, it works fine when only 1 and the last tag is change by using "L" to select the tag.
    However it fails when I specify the block names & tag value
    Any idea? Is it because I cannot use "last" after specifying block name?
    Code:
      (command "-attedit" "y" "LT_FIN" "TAG1" "MATERIALCODE" "L" "value" "Replace" MAT1NUM1 "") ; <--fail
      (command "-attedit" "y" "LT_FIN" "TAG2" "MATERIAL" "L" "value" "Replace" MAT1NUM1 "") ; <--fail
      (command "-attedit" "y" "" "" "" "L" "value" "Replace" MAT1NUM1 "") ; works, but it only allows to change the last tag
  6. #16
    Using
    AutoCAD 2007
    Join Date
    Apr 2013
    Location
    Happy Garden
    Posts
    749
    Default
    Quote Originally Posted by leong1221 View Post
    Code:
    Did you try Lee's function by supplying valid arguments? read the header of his code
    Code:
    (if
    (setq en (car(entsel "\nSelect an attributed block entity.. ")))
    (LM:setattributevalue en "TAG1" MAT1NUM1);whatever TAGs associated
    ;This is an activeX method to populate the attributes list
    Code:
    (defun c:test2 (/ lst s obj)
    ;we assume you have MAT1NUM1 global variable or set default "ML01"
    (setq MAT1NUM1 (cond (MAT1NUM1)("ML01")))
      (prompt "\nSelect an attributed block entity.. ")
      (if (and (setq s (ssget "_+.:S:E:L" '((0 . "INSERT") (66 . 1))))
    	   (setq obj (vlax-ename->vla-object (ssname s 0)))
     	;documented
    	;(setq lst (vlax-safearray->list(variant-value(vla-getattributes obj)))) ; conversion is required
     	;undocumented
          (setq lst (vlax-invoke obj 'getattributes)) ; commonly practiced by Lee Mac, Tharwat etc.. credits to both
          (mapcar ''((x o) (vla-put-TextString o x)) ;or vlax-put
    	      (list MATNUM1 "SECOND" "" "FOURTH" "ETC") ; <-- This is just an example, you can edit any replacement TextString associated to attribute positions
    	      lst
        (princ "\nInvalid selection")
    (vl-load-com)
  7. #17
    Junior Member
    Using
    AutoCAD 2013
    Join Date
    Jan 2013
    Posts
    20
    Default
    Hi hanhphuc, Lee and everyone,
    Thanks very much for helping.
    Just amended a little bit the lisp from you guys to how i need it, please bear with me some of them are using silly methods.
    I'd love to attache the files if it may be of use to anybody.
    P.S. Any further advises are very welcome
    MaterialCodeTest2.dwg
    Code:
    (defun C:QW1 (/ i s mat1 Num1)
                        (entupd blk)
                        val
      (defun LM:setattributevalue ( blk tag val / end enx )
        (while
            (and
                (null end)
                        (entupd blk)
                        (setq end val)
    (defun dtr ( deg ) (* pi (/ deg 180.0)))
    (defun rtd (a)(/ (* a 180.0) pi))
    (setq dist 300)
    (setq Area "BR")
    (setq yline 21900)
    (setq ylineDist 350)
    (setq ML02 "H50MM RECESSED S/S SKIRTING")
      (setq cmde (getvar "cmdecho"))
      (setq osmde (getvar "osmode"))
      (setq oldlayer (getvar "CLAYER"))
      (setq dynmde (getvar "Dynmode"))
      (setvar 'cmdecho 0)
      (setvar 'osmode 0)
      (setvar 'dynmode 1)
    (defun matNum (/ l i s mat1 Num1)
      (setq	i 1
    	l '("BL" "CP" "GL" "FA"	"FB" "ML" "P" "PL" "SP"	"ST" "TL" "WC"
    	    "WD")
      (repeat (length l)
        (setq s (cons (strcat (itoa i) "_" (nth (1- i) l) " / ") s))
        (setq i (1+ i))
      (initget 7)
      (if
        (and
          (setq i (getint (strcat "\nIndex number ["
    			      (apply 'strcat (reverse s))
          (<= i (length l))
          (setq mat1 (nth (1- i) l))
    	(initget 7)
    	(setq i (getint "Enter number 1~20 ? : "))
    	(setq Num1 (itoa i))
    	(<= i 20)
      (princ (strcat Mat1
    		 (if (< i 10)
    		   (strcat "0" Num1)
    		   Num1
      (prompt "\nInvalid Input.. ")
      (setq pt1 (getpoint "\nEnter first point:"))
      (setq pt2 (getpoint "\nEnter sceond point:"))
      (setvar "osmode" osmde)
      (setq pt1B (car pt1))
      (setq pt1C (list pt1B yline))
      (setq pt1D (list (+ (car pt1c) (* '2 dist)) yline))
      (setq pt2B (car pt2))
      (setq pt2C (list pt2B (+ yline ylineDist)))
      (setq pt2D (list (+ (car pt1c) (* '2 dist)) (+ yline ylineDist)))
      (setvar "osmode" 0)
      (Command "-layer" "make" "LEGEND" "c" 4 "" "")
        (setq M1 (substr Mat1Num1 1 2))
        (cond
        ((= M1 "BL")(setq M1 "BLIND")))
        (cond
        ((= M1 "CP")(setq M1 "CARPET")))
        (cond
        ((= M1 "GL")(setq M1 "GLASS")))
        (cond
        ((= M1 "FA")(setq M1 "FABRIC")))
        (cond
        ((= M1 "FB")(setq M1 "FABRIC")))
        (cond
        ((= M1 "ML")(setq M1 "METAL")))
        (cond
        ((= M1 "P")(setq M1 "PAINT")))
        (cond
        ((= M1 "PL")(setq M1 "PLASTIC LAMINATE")))
        (cond
        ((= M1 "SP")(setq M1 "SPECIAL FINISH")))
        (cond
        ((= M1 "ST")(setq M1 "STONE")))
        (cond
        ((= M1 "TL")(setq M1 "TILE")))
        (cond
        ((= M1 "WC")(setq M1 "WALL COVERING")))
        (cond
        ((= M1 "WD")(setq M1 "WALL PAPER")))
        (cond
          ((= Mat1Num1 "ML02")(setq M1 ML02)))
      (command "Qleader" pt1 pt1c pt1d "LT_FIN" pt1d "" "" "")
      (command "-attedit" "y" "" "" "" "L" "value" "Replace" Mat1Num1 "")
    (setq en (entlast))
    (LM:setattributevalue en "TAG1" M1);whatever TAGs associated
    (LM:setattributevalue en "TAG2" Mat1Num1);whatever TAGs associated
        (command "Qleader" pt2 pt2c pt2d "LT_FIN" pt2d "" "" "")
        (command "-attedit" "y" "" "" "" "L" "value" "Replace" MAT2NUM2 "")
      (setq M2 (substr mat2num2 1 2))
        (cond
        ((= M2 "BL")(setq M2 "BLIND")))
        (cond
        ((= M2 "CP")(setq M2 "CARPET")))
        (cond
        ((= M2 "GL")(setq M2 "GLASS")))
        (cond
        ((= M2 "FA")(setq M2 "FABRIC")))
        (cond
        ((= M2 "FB")(setq M2 "FABRIC")))
        (cond
        ((= M2 "ML")(setq M2 "METAL")))
        (cond
        ((= M2 "P")(setq M2 "PAINT")))
        (cond
        ((= M2 "PL")(setq M2 "PLASTIC LAMINATE")))
        (cond
        ((= M2 "SP")(setq M2 "SPECIAL FINISH")))
        (cond
        ((= M2 "ST")(setq M2 "STONE")))
        (cond
        ((= M2 "TL")(setq M2 "TILE")))
        (cond
        ((= M2 "WC")(setq M2 "WALL COVERING")))
        (cond
        ((= M2 "WD")(setq M2 "WALL PAPER")))
          (cond
          ((= Mat2Num2 "ML02")(setq M2 ML02)))
      (if
    (setq en (entlast))
    (LM:setattributevalue en "TAG1" M2)
    (LM:setattributevalue en "TAG2" MAT2NUM2)
    (vl-load-com)
      (setvar 'cmdecho cmde)
      (setvar 'osmode osmde)
      (setvar 'dynmode dynmde)
      (setvar 'CLAYER oldlayer)
Similar Threads
  1. strcat help sought
    By diarmuid in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th Dec 2017, 08:58 am
  2. Need some help with getstring
    By pmxcad in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Nov 2017, 08:21 pm
  3. Getstring Question
    By harrison-matt in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Oct 2010, 10:57 pm
  4. problem with strcat
    By Sweety in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Aug 2010, 08:39 pm
  5. getstring
    By jay3791 in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Sep 2009, 07:21 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
