Results 1 to 3 of 3
    Full Member
    Construction
    AutoCAD 2018
    Nov 2017
    40
    Default Multileader with blocks
    I have created a series of multileader styles using blocks instead of text. The blocks I have used are blocks I have inserted into the drawing. They all work really well. I want to run the multileader style in a lisp routine. The reason for this is so l can use menu icons to run various multileader lisp files. But what I need to do is to be able to set a different multileader style to current within each of the lisp files. This way I can insert leaders with different blocks attached. So after all that is there a variable that I can use in my lisp file that will allow me to set a different mleader style to be current in each lisp file to get a different block on the leaders
    I hope I have explained myself clear enough
    Super Member
    not applicable
    Jun 2016
    673
    Code:
    (setvar 'cmleaderstyle "MyName")
    BricsCAD 18
    Full Member
    Construction
    AutoCAD 2018
    Nov 2017
    40
    Thank you very much Roy I now have this operation working prefect.
    Just another question for you.
    Once I have inserted the mleader with the specific block attached to it I then want to add another block to the existing mleader block and make the whole thing binding as 1 mleader. Can I do this with lisp? So when I use the grip points on the leader to move it I would like to see the entire object move including the newly added block.
    Regards Tony
  1. Multileader mask on
    By broncos15 in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th Oct 2015, 10:04 am
  2. Multileader ?
    By NH3man! in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 7th Feb 2010, 07:48 pm
  3. Multileader Tag Value
    By MMS in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Jul 2008, 07:19 am
  4. about Multileader
    By alijahed in forum AutoCAD General
    Last Post: 19th Dec 2007, 02:36 am
  5. Where is my Multileader?
    By SLW210 in forum AutoCAD Drawing Management & Output
    Last Post: 29th Sep 2007, 05:41 am
