Results 1 to 3 of 3
    Super Member wimal's Avatar
    Construction
    wimal's Discipline Details
    cadoperator
    Construction
    AutoCAD 2016
    Oct 2011
    sri lanka
    511
    Default Over kill by lisp
    How can I set the setting of overkill command by lisp.I mean what are the system
    variables of overkill command.
    Super Member halam's Avatar
    AutoCAD 2017
    Jul 2015
    699
    You can script it, so it can be a lisp probably
    use the -overkill variant
    Command: -overkill
    Select objects: all
    5 found
    2 were not in current space.
    Select objects:
    Current settings: Tolerance=0.000001, Ignore=None, Optimize polylines=Yes, Combine partial overlap=Yes, Combine end-to-end=Yes
    Enter an option to change [Done/Ignore/tOlerance/optimize Plines/combine parTial overlap/combine Endtoend/Associativity] <done>:
    2 duplicate(s) deleted
    0 overlapping object(s) or segment(s) deleted
    Modelling is done with two hands, 2d & 3d. Let it work together..
    https://twitter.com/halammerts
    Construction
    cadoperator
    Construction
    AutoCAD 2016
    Oct 2011
    sri lanka
    511
    Quote Originally Posted by halam View Post
    Command: -overkill
    Select objects: all
    5 found
    Select objects:
    Yes -overkill fulfilled my requirements Thanks for the advice.
  1. All in one Merge LISP routine! One shot one kill.
    By tmelancon in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Aug 2017, 02:01 pm
  2. How to kill phantom UCS?
    By draknar in forum AutoCAD Beginners' Area
    Last Post: 10th Feb 2014, 04:40 pm
