Results 1 to 7 of 7
    Forum Newbie
    AutoCAD LT 2009
    Oct 2014
    4
    Unhappy Replace specific text with closest mtext
    Hello guys,
    I have a drawing where someone used mtext as names for specific blocks, I need to extract the coordinates for those blocks but the mtext base point is not where the block base point is.
    Therefore I just put an attribute definition with the " * " sign and I have to manually replace it with the mtext number., so I can later use eattext to extract coordinates.
    Since I have a huge number of those symbols (around a thousand in the drawing) I was hoping if there is a lisp that would replace the * with the closes mtext content.
    I'm attaching an example of what I have in the drawing, basically the * needs to change to 4885.
    Is there a lisp that does something like that?
    Thx.
    damn.dwg
    Forum Newbie
    Architectural
    AutoCAD 2015
    Nov 2017
    6
    i don't know if it will help you,
    but lee-mac have a lisp to change the base point of a bloc without moving the block? http://www.lee-mac.com/changeblockinsertion.html
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,126
    I have moved your thread to the AutoLISP, Visual LISP & DCL Forum.
    Super Member
    ronjonp's Computer Details
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    889
    If you're using AutoCAD LT like your profile shows, then you can't use lisp.
  5. #5
    Forum Newbie
    AutoCAD LT 2009
    Oct 2014
    4
    @Bibix
    yeah I know about that one, unfortunately it's no help...
    @SLW210
    thank you, sorry about that, my bad
    @ronjonp
    no ron I'm on a full version, never mind about the profile
  6. #6
    Forum Newbie
    AutoCAD LT 2009
    Oct 2014
    4
    I've found this useful script that let's me copy(or swap) text which would also help me, it's a solution where I will have to do a huge number of clicks but again shorter than clicking at least twice to edit each * sign
    The only problem with this script is that it keeps repeating the text you originally selected, I would need one that asks for input after it has done one copy/swap
    http://www.lee-mac.com/copytext.html
  7. #7
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,702
    I think the best thing to do is to redo the #ptnum block over again including the attribute. You can make attributes visible or not so could have ptnum turn off.
    How did you get the pts in the first place was it a csv file P,N,E,Z,D etc even with LT you can do some pretty detailed stuff in excel that would fix this problem so the Block and mtext are correctly related.
    In civil software this is common and in CIV3d you have styles to do this.
    Lastly you could cross relate the block insertion point to the mtext insertion pt via a max distance and redo the mtext at correct ins pt, lower left, right justified etc. But sorry not about to spend a lot of time trying to retro it. Move forward and fix for next time. Steven-g may have something he is a wiz at Excel & LT.
  1. replace prompt with select all (mtext)
    By jt6572 in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Mar 2017, 12:16 am
  2. How to replace a MTEXT of an attribute
    By LauKwokFai in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Mar 2017, 08:24 am
  3. Replies: 16
    Last Post: 17th Jan 2015, 08:05 am
  4. LISP - Do routine if specific text is found in a specific block attribute
    By h0okem in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Nov 2011, 05:53 am
  5. How to find all mtext which is using a specific text style?
    By salmonrose in forum AutoCAD Beginners' Area
    Last Post: 3rd Feb 2010, 06:27 pm
