Results 1 to 4 of 4
    Full Member benhubel's Avatar
    benhubel's Computer Details
    Windows 7
    Manufacture
    benhubel's Discipline Details
    Waterjet Programmer
    Manufacture
    AutoCAD 2012
    Dec 2015
    Dallas, Texas
    90
    Default Define generated variables locally
    I have been experimenting with generating variables through code rather than defining them manually. The problem is that when the program creates them, they are defined as global variables. Is there a way to generate them as local variables instead?
    Below is the sample code that I wrote for testing it.
    Code:
    ;ListToVariables creates variables named testvar0, testvar1, testvar2, etc.
    ;Each newly created variable contains the contents of the correlated slot from testlist.
    (defun c:test ( / testlist )
    	(setq testlist (list "aaa" "bbb" "ccc" "ddd" "eee"))
    	(ListToVariables testlist)
    (defun ListToVariables ( listname / i )
    	(setq i 0)
    	(repeat (length listname)
    		(set (read (strcat "testvar" (rtos i 2 0))) (nth i listname))
    		(setq i (1+ i))
    I just now discovered for the first time that I am prone to memory loss.
    Forum Deity David Bethel's Avatar
    Multi-disciplinary
    David Bethel's Discipline Details
    Multi-disciplinary
    Commercial Food Service
    AutoCAD pre 2000
    Dec 2003
    Newport News, Virginia
    2,548
    You can but it is a RPIA
    Your best bet is to use a standard name convention for these types that will be used for that session only
    I use a prefix of gv_ for variable that are global and set for reuse and tv_ for temp variables
    -David
    R12 (Dos) - A2K
    Windows 7
    Manufacture
    Waterjet Programmer
    Manufacture
    AutoCAD 2012
    Dec 2015
    Dallas, Texas
    90
    Quote Originally Posted by David Bethel View Post
    -David
    That makes sense, and it sounds like the route I might have to go. Out of curiosity, I'm still interested to see how generated local variables could be done though. If anybody has any examples, or a link to any sort of documentation describing it, I'd love to check it out. The only way I can think of right now is to write it as an intermediate program that writes its own function which declares the variables locally.
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,474
    Maybe...
    Code:
    ; (ListToVariables "hello" '(44 55 88))
    (defun ListToVariables ( pref L / varnm i r )
      (setq i 0)
      (foreach x L
        (set (read (setq varnm (strcat pref (itoa (setq i (1+ i)))))) x)
        (setq r (cons varnm r))
      (reverse r)
    Code:
    (ListToVariables "hello" '(44 55 88)) >> ("hello1" "hello2" "hello3")
    hello1 >> 44
    hello2 >> 55
    hello3 >> 88
    hello4 >> nil
  1. control layers appearance locally
    By samifox in forum AutoCAD General
    Last Post: 23rd Oct 2012, 11:51 am
  2. Save plot style locally
    By jgbgod in forum AutoCAD General
    Last Post: 27th Jan 2012, 03:56 pm
  3. Replies: 0
    Last Post: 13th Jan 2011, 02:30 am
  4. Hotfix - Refresh From Vault overwrites locally saved files
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 23rd Nov 2010, 08:20 am
  5. If an AUGI CAD Camp is available locally, will you attend in 2010?
    By CAD Panacea in forum AutoCAD RSS Feeds
    Last Post: 14th Jan 2010, 07:38 am
Tags for this Thread
