Results 1 to 9 of 9
Thread: 3D Sweep help!
    Full Member
    Greendamo's Computer Details
    Windows 7
    HP
    4gig
    Nvidia Quatro FX 1800
    1Tb
    24" Samsung
    Manufacture
    Greendamo's Discipline Details
    CAD Engineer
    Manufacture
    AutoCAD 2012
    Jul 2010
    England, Solihull
    45
    Unhappy 3D Sweep help!
    Hi,
    When using the sweep command on handrail profile, is there a way of stopping the sweep from twisting the profile out of shape? i have attached an image showing what i get.
    I know there is a command in sketchup called 'follow me' which works well. I cant find anything in Autocad that gives me the correct results!
    Thanks for you help in advance.
    Damian
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Can you attach a copy of the drawing to your next post? Thanks.
    Full Member
    Windows 7
    HP
    4gig
    1Tb
    24" Samsung
    Manufacture
    CAD Engineer
    Manufacture
    AutoCAD 2012
    Jul 2010
    England, Solihull
    45
    It wont let me attach. says the file size exceeds the limit!
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    We need a drawing with the railing profile and the "path" the railing will ultimately follow. Nothing else.
  5. #5
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    Have you looked at the command line options as you sweep?
    What have you tried? There is Alignment and Twist (which has options).
    The following prompts are displayed.
    Objects to Sweep
    Specifies an object to use as the sweep profile.
    Sweep Path
    Specifies the sweep path based on the object you select.
    Mode
    Controls whether the sweep action creates a solid or a surface. Surfaces are swept as either NURBS surfaces or procedural surfaces, depending on the SURFACEMODELINGMODE system variable.
    Alignment
    Specifies whether the profile is aligned to be normal to the tangent direction of the sweep path.
    If the profile is not perpendicular (normal) to the tangent of the start point of the path, then the profile automatically aligns. Enter No at the alignment prompt to prevent this.
    Base Point
    Specifies a base point for the objects to be swept.
    Scale
    Specifies a scale factor for a sweep operation. The scale factor is uniformly applied to the objects that are swept from the start to the end of the sweep path.
    • Reference. Scales the selected objects based on the length you reference by picking points or entering values.
    Twist
    Sets a twist angle for the objects being swept. The twist angle specifies the amount of rotation along the entire length of the sweep path.
    Bank. Specifies whether the curve(s) being swept will naturally bank (rotate) along a 3D sweep path (3D polyline, spline, or helix).
  6. #6
    Full Member
    Windows 7
    HP
    4gig
    1Tb
    24" Samsung
    Manufacture
    CAD Engineer
    Manufacture
    AutoCAD 2012
    Jul 2010
    England, Solihull
    45
    I have attached the geometry.
  7. #7
    Senior Member
    AutoCAD 2008
    Oct 2003
    Germany
    292
    Hi Greendamo,
    does the attachement fit to your intentions??
    Regards
    Jochen
  8. #8
    Forum Deity SEANT's Avatar
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    This one I tried with an ArrayAlongPath/Loft methodology. Not perfect, but not too bad either.
  9. #9
    Full Member
    Windows 7
    HP
    4gig
    1Tb
    24" Samsung
    Manufacture
    CAD Engineer
    Manufacture
    AutoCAD 2012
    Jul 2010
    England, Solihull
    45
    Hi Seant,
    That looks great... shame i cant get that command to do the same for some reason :-(
  1. Sweep
    By Lentezza in forum AutoCAD 3D Modelling & Rendering
    Last Post: 19th Mar 2013, 06:07 pm
  2. Unable to sweep object when attempting helical sweep for pipe thread
    By eKretz in forum AutoCAD 3D Modelling & Rendering
    Last Post: 24th Dec 2012, 02:26 pm
  3. Sweep bug
    By laranjo123 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 20th Apr 2012, 05:22 pm
  4. sweep
    By ica_cici in forum AutoCAD 3D Modelling & Rendering
    Last Post: 29th Apr 2010, 01:52 am
  5. Sweep
    By ausmods in forum Autodesk Inventor
    Last Post: 12th May 2009, 12:11 pm
