Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Junior Member
    Mechanical
    AutoCAD 2015
    Nov 2017
    10
    Default Find a Block and Send it to Another Layer
    I am trying to capture items on layer “0”. I first turn all layers off except “0”, but I don’t know how to code that yet so I did it manually. I am left with one object on that layer and it is a block. My goal is to window in on an area and capture the object and sent it to another layer (in this case, the layer name is “FTG-IsoCont”). I have run the following lisp and it is not able to find the block.
    Can someone suggest a fix?
    Code:
    ; Changes selected objects to Layer from Prompt
      ; Changes selected objects to Layer FTG-IsoCont
      (defun c:SetWinToLayerFTG-IsoCont ()
      (if (setq ss1 (ssget "_C" '(0.625 1.95) '(7.15 10.45) '((0 . "FTG-IsoCont"))))
      (command "change" ss1 "" "p" "la" "FTG-IsoCont" "")
      (alert "No Objects Found")
      );; End of if
    Greg
    Super Member
    ronjonp's Computer Details
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    530
    You need to use group code 8 for the layer name filter:
    Code:
    (setq ss1 (ssget "_C" '(0.625 1.95) '(7.15 10.45) '((0 . "insert") (8 . "FTG-IsoCont"))))
    Junior Member
    Mechanical
    AutoCAD 2015
    Nov 2017
    10
    Quote Originally Posted by ronjonp View Post
    Code:
    thank you for the code snippet.
    But sadly it didn't work.
    Below is an image and some attribute data of the block.
    Greg
    Junior Member
    Mechanical
    AutoCAD 2015
    Nov 2017
    10
    Code:
    Thanks, but the code did not work.
    I tried running it more than once and then reloading, but it remained unmoved.
    Greg
  5. #5
    Super Member
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    530
    A test drawing would help.
  6. #6
    Junior Member
    Mechanical
    AutoCAD 2015
    Nov 2017
    10
    Can you PM me your email? I just joined the group today and I don't think I have the requisite number of posts yet to be somewhat vetted.
    Greg
  7. #7
    Super Member
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    530
    Read your post a bit closer, if you want to select items on layer 0 using ssget, use this instead.
    Code:
    (setq ss1 (ssget "_C" '(0.625 1.95) '(7.15 10.45) '((8 . "0"))))
    No need to turn off layers .. that's part of the beauty of ssget filters.
  8. #8
    Junior Member
    Mechanical
    AutoCAD 2015
    Nov 2017
    10
    Code:
    That one did not work either.
    I'm trying to upload a .dwg.
    Greg
  9. #9
    Luminous Being
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    9,819
    Why would you not just do find all ? You can add (cons 2 Blkname) also. For me pick a block get all the stuff like name and layer then make the selection set.
    Code:
    (defun c:chglay-0 ( / obj ss lay blkname)
    (setq obj (vlax-ename->vla-object (car (entsel "\nPick "))))
    (setq lay (vla-get-layer obj))
    (if (= (vla-get-ObjectName obj) "AcDbBlockReference")
    (setq blkname (vla-get-name obj))
    (setq ss (ssget "x" (list (cons 0 "insert")(cons 8 lay)(cons 2 blkname))))
    (setq ss (ssget "x" (list (cons 0 "insert")(cons 8 lay))))
    (command "CHprop" ss "" "la" "0" "")
  10. #10
    Junior Member
    Mechanical
    AutoCAD 2015
    Nov 2017
    10
    Quote Originally Posted by BIGAL View Post
    Code:
    BIGAL this does not work for me, at least as it is coded in this form. I need it to automatically capture objects in a certain sized window. The master plan is weaving this code into a larger routine, so that when the drawing is opened it is automatically cleaned up so that the user does not have to provide input.
    Maybe just a few lines need to be revised?
    Greg
  1. How to find objects that are inside blocks on layers other than the block's layer?
    By ColinPearson in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 17th Jan 2016, 05:22 am
  2. send data to attributes inside a block
    By samifox in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Jun 2014, 09:55 pm
  3. Send all objects on certain layer from paper space into model space.
    By gaddyzt in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Apr 2014, 06:51 pm
  4. Find and/or Create a Layer using LISP
    By FindAPath in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Jul 2006, 10:04 pm
  5. Trying to find a layer tool in 2007
    By palace-333 in forum AutoCAD Drawing Management & Output
    Last Post: 24th May 2006, 02:42 pm
