Results 1 to 6 of 6
    Senior Member
    Construction
    wimal's Discipline Details
    cadoperator
    Construction
    AutoCAD 2016
    Oct 2011
    sri lanka
    419
    Default Acad.lin file load by lisp
    Pl. can you give me a lisp code to load acad.lin file
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,447
    What exactly is the goal here? Is it to load every linetype that is included in acad.lin?
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    11,797
    Something like this is what I have in my old notes.
    Code:
    (command "_.-linetype" "load" "*" "path to .lin" "")
    You can use the command line version of the Layer command (-LAYER) to load linetypes as well, at least you used to and seems to work in AutoCAD 2011.
    Senior Member mostafa badran's Avatar
    mostafa badran's Computer Details
    win 7
    Dell
    Core I7
    12 GB
    2 GB
    350 GB
    Fujitsu
    Electrical
    mostafa badran's Discipline Details
    Cad Operator
    Electrical
    Power & low current system.
    AutoCAD 2014
    May 2010
    KSA
    232
    Try this.
    Code:
    (defun c:loadltypes ( / fn f rl ltname ltypes )
      (setq fn (open (setq f (findfile "acadiso.lin")) "r"))
      (while (setq rl (read-line fn))
        (if (eq "*" (substr rl 1 1)) (setq ltname (substr rl 1 (vl-string-position (ascii ",") rl))))
        (if ltname
            (setq ltname (vl-string-left-trim "*" ltname))
            (setq ltypes (cons ltname ltypes))
      (foreach ln ltypes
        (command "_.linetype" "l" f "" "s" ln "")
      (command "_.linetype" "s" "ByLayer" "")
    What doesn't kill you makes you stronger
  5. #5
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    729
    Lee Mac's http://www.lee-mac.com/loadlinetype.html will search lin files and load a list of linetypes giving the option to redefine them. I use several lin files as an Arial font used by an Arial.lin produces clean visible dotted and arrow linetypes. I use another lisp to add the text style first if needed.
    Code:
    *STriangle, Solid Triangle__/_\_/_\__/_\_/_\_/_\_
    S,.000000001,-.05,["\U+25BA",Arial,S=0.02,R=90,Y=-.0019],-.05
    *ARROWH,Arrowhead  >  >  >  >  >  >  >
    A,.000001,-3,["\U+25BA",Arial,S=3,R=0,X=-1.35,Y=-1.35],.000001,-4
    *ArialARROW,Arrow1  >  >  >  >  >  >  >
    S,.000001,-3,["\U+25AC",Arial,S=3,R=0,X=-1.35,Y=-1.05],.000001,["\U+25BA",Arial,S=3,R=0,X=0.5,Y=-1.42],.000001,-4
    *ArialDOT,Dot . . . . . . . . . . . . . . . . . . . . . . . .
    A,0,-.125,["\U+2022",Arial,S=.05,Y=-.024],-.125
    *ArialDOT2,Dot (.5x) ........................................
    A,0,-.0625,["\U+2022",Arial,S=.05,Y=-.012],-.0625
    *ArialDOTX2,Dot (2x) .  .  .  .  .  .  .  .  .  .  .  .  .  .
    A,0,-.25,["\U+2022",Arial,S=.05,Y=-.048],-.25
    My Acad.lin and FDOT.lin files are huge. I'd never load all of either of them in a drawing.
    Layer 0 for ByBlock Block entities, everything else ByLayer. So many issues can be solved with good templates.
  6. #6
    Senior Member
    Construction
    cadoperator
    Construction
    AutoCAD 2016
    Oct 2011
    sri lanka
    419
    Thanks everybody.
  1. Load Mnu file via lisp
    By MastroLube in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Aug 2015, 05:01 am
  2. Is it wise to load all LISP codes at ACAD startup?
    By khoshravan in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Aug 2011, 06:49 am
  3. LISP (or other) to load custom .pgp files (acad.pgp)
    By walton10 in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th May 2010, 02:15 pm
  4. Should I load one lisp file or several?
    By yrnomad in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Mar 2009, 09:11 pm
  5. Help!!! My default acad.mnl file doesn't auto load!
    By greg.wright1 in forum AutoCAD Drawing Management & Output
    Last Post: 12th Feb 2007, 01:57 pm
