Need Automatic Grid Labels lisp
structo
I'm feeling generous today so:
*I've created an attributed block rather than inserting separate text & circle.
(defun c:foo (/ _dxf _layout a b c d i n o p2 s sp x)
 ;; RJP - 11.16.2017
 (defun _layout (name / o)
   (if	(and (setq o (cdr (assoc -1 (dictsearch (namedobjdict) "ACAD_LAYOUT"))))
     (setq o (cdr (assoc -1 (dictsearch o name))))
     (vla-get-block (vlax-ename->vla-object o))
 (defun _dxf (code ename) (cond (ename (cdr (assoc code (entget ename))))))
 ;; This checks for metric drawings ( assuming it's set correctly  )
 (if (= 0 (getvar 'measurement))
   (setq c 18.
  d 18.
  n "rjpbubble"
   (setq c 0.24
  d 0.2
  n "rjpbubble_metric"
 (if (null (tblobjname "block" n))
   (progn (entmake (list '(0 . "BLOCK")
		  '(100 . "AcDbEntity")
		  '(67 . 0)
		  '(8 . "0")
		  '(100 . "AcDbBlockReference")
		  '(66 . 1)
		  (cons 2 n)
		  '(10 0. 0. 0.)
		  '(70 . 2)
   (entmake (list '(0 . "CIRCLE")
		  '(67 . 0)
		  '(62 . 53)
		  '(8 . "grid-circle")
		  '(100 . "AcDbCircle")
		  '(10 0. 0. 0.)
		  ;; This is the radius
		  (cons 40 c)
   (entmake (list '(0 . "ATTDEF")
		  '(67 . 0)
		  '(62 . 121)
		  '(8 . "Grid Text")
		  '(100 . "AcDbText")
		  '(10 -6.9925 -9. 0.)
		  ;; Text height
		  (cons 40 d)
		  '(1 . "-")
		  '(50 . 0.)
		  '(41 . 1.)
		  '(51 . 0.)
		  (cons	7
			(if (tblsearch "style" "LA-grid")
			  "LA-grid"
			  "Standard"
		  '(71 . 0)
		  '(72 . 1)
		  '(11 0. 0. 0.)
		  '(100 . "AcDbAttributeDefinition")
		  '(280 . 0)
		  '(3 . "Number")
		  '(2 . "#")
		  '(70 . 0)
		  '(73 . 0)
		  '(74 . 2)
		  '(280 . 1)
   (entmake '((0 . "ENDBLK") (100 . "AcDbBlockEnd") (8 . "0")))
 (if (tblobjname "block" n)
   (if	(and (setq s (ssget '((0 . "line"))))
     (setq s (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))))
     (setq sp (_layout (_dxf 410 (car s))))
     (setq s (apply 'append (mapcar '(lambda (x) (list (_dxf 10 x) (_dxf 11 x))) s)))
     (setq a (apply 'min (mapcar 'car s)))
     (setq b (apply 'max (mapcar 'cadr s)))
     (progn (setq i 0)
     (foreach p	(vl-sort (vl-remove-if-not '(lambda (x) (equal a (car x) 1e-) s)
			 '(lambda (a b) (> (cadr a) (cadr b)))
       (setq p2 (vlax-3d-point (list (- (car p) c) (cadr p) (caddr p))))
       (if (and	(setq o (vla-insertblock sp p2 n 1 1 1 0))
		(setq o (vlax-invoke o 'getattributes))
	 (vla-put-textstring (car o) (itoa (setq i (1+ i))))
     (setq i 64)
     (foreach p	(vl-sort (vl-remove-if-not '(lambda (x) (equal b (cadr x) 1e-) s)
			 '(lambda (a b) (< (car a) (car b)))
       (setq p2 (vlax-3d-point (list (car p) (+ c (cadr p)) (caddr p))))
	 (vla-put-textstring
	   (car o)
	   (if (= 91 (1+ i))
	     (chr (setq i 65))
	     (chr (setq i (1+ i)))
   (print "Block could not be created .. bye...")
(vl-load-com)
Edited by ronjonp
BTW your entmaking BLOCK reminded me that I wanted to finish a generic entmake INSERT, so here it is:
[color=#8b4513]; [b][color=BLACK]([/color][/b]VanillaINSERT [b][color=FUCHSIA]([/color][/b]getpoint[b][color=FUCHSIA])[/color][/b] [color=#2f4f4f]"VLD_Tag"[/color] [b][color=FUCHSIA]([/color][/b]getvar 'ctab[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b][/color]
[b][color=BLACK]([/color][/b]defun VanillaINSERT [b][color=FUCHSIA]([/color][/b] p nm spc / GetBlkAttDefProps atts r [b][color=FUCHSIA])[/color][/b]
 [color=#8b4513]; '[b][color=FUCHSIA]([/color][/b]87 114 105 116 116 101 110 32 66 121 32 71 114 114 114[b][color=FUCHSIA])[/color][/b][/color]
 [b][color=FUCHSIA]([/color][/b]setq GetBlkAttDefProps
   [b][color=NAVY]([/color][/b]lambda [b][color=MAROON]([/color][/b] bnm / e enx typ L [b][color=MAROON])[/color][/b]
     [b][color=MAROON]([/color][/b]and
       [b][color=GREEN]([/color][/b]setq e [b][color=BLUE]([/color][/b]tblobjname [color=#2f4f4f]"BLOCK"[/color] bnm[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b]
       [b][color=GREEN]([/color][/b]= 2 [b][color=BLUE]([/color][/b]logand 2 [b][color=RED]([/color][/b]cdr [b][color=PURPLE]([/color][/b]assoc 70 [b][color=TEAL]([/color][/b]setq enx [b][color=OLIVE]([/color][/b]entget e[b][color=OLIVE])[/color][/b][b][color=TEAL])[/color][/b][b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b]
       [b][color=GREEN]([/color][/b]setq e [b][color=BLUE]([/color][/b]cdr [b][color=RED]([/color][/b]assoc -2 enx[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b]
       [b][color=GREEN]([/color][/b]while [b][color=BLUE]([/color][/b]and e [b][color=RED]([/color][/b]setq enx [b][color=PURPLE]([/color][/b]entget e[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b]/= [color=#2f4f4f]"SEQEND"[/color] [b][color=PURPLE]([/color][/b]setq typ [b][color=TEAL]([/color][/b]cdr [b][color=OLIVE]([/color][/b]assoc 0 enx[b][color=OLIVE])[/color][/b][b][color=TEAL])[/color][/b][b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b]
         [b][color=BLUE]([/color][/b]if [b][color=RED]([/color][/b]= [color=#2f4f4f]"ATTDEF"[/color] typ[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]setq L [b][color=PURPLE]([/color][/b]cons [b][color=TEAL]([/color][/b]vl-remove-if-not [b][color=OLIVE]([/color][/b]function [b][color=GRAY]([/color][/b]lambda [b][color=AQUA]([/color][/b]x[b][color=AQUA])[/color][/b] [b][color=AQUA]([/color][/b]member [b][color=LIME]([/color][/b]car x[b][color=LIME])[/color][/b] '[b][color=LIME]([/color][/b]1 2 3 7 10 11 40[b][color=LIME])[/color][/b][b][color=AQUA])[/color][/b][b][color=GRAY])[/color][/b][b][color=OLIVE])[/color][/b] enx[b][color=TEAL])[/color][/b] L[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b]
         [b][color=BLUE]([/color][/b]setq e [b][color=RED]([/color][/b]entnext e[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b]
       [b][color=GREEN])[/color][/b][color=#8b4513]; while[/color]
     [b][color=MAROON])[/color][/b][color=#8b4513]; and[/color]
     [b][color=MAROON]([/color][/b]reverse L[b][color=MAROON])[/color][/b]
   [b][color=NAVY])[/color][/b][color=#8b4513]; lambda[/color]
 [b][color=FUCHSIA])[/color][/b][color=#8b4513]; setq GetBlkAttDefProps[/color]
 [b][color=FUCHSIA]([/color][/b]cond
   [b][color=NAVY]([/color][/b] [b][color=MAROON]([/color][/b]tblsearch [color=#2f4f4f]"BLOCK"[/color] nm[b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]setq atts [b][color=GREEN]([/color][/b]GetBlkAttDefProps nm[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
     [b][color=MAROON]([/color][/b]if
       [b][color=GREEN]([/color][/b]setq r
         [b][color=BLUE]([/color][/b]mapcar 'entmake
           [b][color=RED]([/color][/b]append
             [b][color=PURPLE]([/color][/b]list
               [b][color=TEAL]([/color][/b]append
                 '[b][color=OLIVE]([/color][/b][b][color=GRAY]([/color][/b]0 . [color=#2f4f4f]"INSERT"[/color][b][color=GRAY])[/color][/b][b][color=GRAY]([/color][/b]100 . [color=#2f4f4f]"AcDbEntity"[/color][b][color=GRAY])[/color][/b][b][color=GRAY]([/color][/b]67 . 0[b][color=GRAY])[/color][/b][b][color=OLIVE])[/color][/b] [b][color=OLIVE]([/color][/b]list [b][color=GRAY]([/color][/b]cons 410 spc[b][color=GRAY])[/color][/b][b][color=OLIVE])[/color][/b] [b][color=OLIVE]([/color][/b]list [b][color=GRAY]([/color][/b]cons 8 [b][color=AQUA]([/color][/b]getvar 'clayer[b][color=AQUA])[/color][/b][b][color=GRAY])[/color][/b][b][color=OLIVE])[/color][/b] '[b][color=OLIVE]([/color][/b][b][color=GRAY]([/color][/b]100 . [color=#2f4f4f]"AcDbBlockReference"[/color][b][color=GRAY])[/color][/b][b][color=OLIVE])[/color][/b]
                 [b][color=OLIVE]([/color][/b]list [b][color=GRAY]([/color][/b]cons 66 [b][color=AQUA]([/color][/b]if atts 1 0[b][color=AQUA])[/color][/b][b][color=GRAY])[/color][/b] [b][color=GRAY]([/color][/b]cons 2 nm[b][color=GRAY])[/color][/b] [b][color=GRAY]([/color][/b]cons 10 p[b][color=GRAY])[/color][/b][b][color=OLIVE])[/color][/b]
                 '[b][color=OLIVE]([/color][/b][b][color=GRAY]([/color][/b]41 . 1.[b][color=GRAY])[/color][/b][b][color=GRAY]([/color][/b]42 . 1.[b][color=GRAY])[/color][/b][b][color=GRAY]([/color][/b]43 . 1.[b][color=GRAY])[/color][/b][b][color=GRAY]([/color][/b]50 . 0.0[b][color=GRAY])[/color][/b][b][color=GRAY]([/color][/b]70 . 0[b][color=GRAY])[/color][/b][b][color=GRAY]([/color][/b]71 . 0[b][color=GRAY])[/color][/b][b][color=GRAY]([/color][/b]44 . 0.0[b][color=GRAY])[/color][/b][b][color=GRAY]([/color][/b]45 . 0.0[b][color=GRAY])[/color][/b][b][color=GRAY]([/color][/b]210 0.0 0.0 1.0[b][color=GRAY])[/color][/b][b][color=OLIVE])[/color][/b]
               [b][color=TEAL])[/color][/b][color=#8b4513]; append[/color]
             [b][color=PURPLE])[/color][/b][color=#8b4513]; list[/color]
             [b][color=PURPLE]([/color][/b]if atts
               [b][color=TEAL]([/color][/b]mapcar
                   [b][color=GRAY]([/color][/b]lambda [b][color=AQUA]([/color][/b]x / pt10 pt11 [b][color=AQUA])[/color][/b]
                     [b][color=AQUA]([/color][/b]setq pt10 [b][color=LIME]([/color][/b]mapcar '+ p [b][color=SILVER]([/color][/b]cdr [b][color=YELLOW]([/color][/b]assoc 10 x[b][color=YELLOW])[/color][/b][b][color=SILVER])[/color][/b][b][color=LIME])[/color][/b][b][color=AQUA])[/color][/b]
                     [b][color=AQUA]([/color][/b]setq pt11 [b][color=LIME]([/color][/b]mapcar '+ p [b][color=SILVER]([/color][/b]cdr [b][color=YELLOW]([/color][/b]assoc 11 x[b][color=YELLOW])[/color][/b][b][color=SILVER])[/color][/b][b][color=LIME])[/color][/b][b][color=AQUA])[/color][/b]
                     [b][color=AQUA]([/color][/b]append
                       '[b][color=LIME]([/color][/b][b][color=SILVER]([/color][/b]0 . [color=#2f4f4f]"ATTRIB"[/color][b][color=SILVER])[/color][/b][b][color=SILVER]([/color][/b]100 . [color=#2f4f4f]"AcDbEntity"[/color][b][color=SILVER])[/color][/b][b][color=SILVER]([/color][/b]67 . 0[b][color=SILVER])[/color][/b][b][color=LIME])[/color][/b]
                       [b][color=LIME]([/color][/b]list [b][color=SILVER]([/color][/b]cons 410 spc[b][color=SILVER])[/color][/b][b][color=LIME])[/color][/b]
                       '[b][color=LIME]([/color][/b][b][color=SILVER]([/color][/b]8 . [color=#2f4f4f]"0"[/color][b][color=SILVER])[/color][/b][b][color=LIME])[/color][/b]
                       '[b][color=LIME]([/color][/b][b][color=SILVER]([/color][/b]100 . [color=#2f4f4f]"AcDbText"[/color][b][color=SILVER])[/color][/b][b][color=LIME])[/color][/b]
                       [b][color=LIME]([/color][/b]list [b][color=SILVER]([/color][/b]cons 10 pt10[b][color=SILVER])[/color][/b][b][color=LIME])[/color][/b]
                       [b][color=LIME]([/color][/b]list [b][color=SILVER]([/color][/b]assoc 40 x[b][color=SILVER])[/color][/b][b][color=LIME])[/color][/b]
                       [b][color=LIME]([/color][/b]list [b][color=SILVER]([/color][/b]assoc 1 x[b][color=SILVER])[/color][/b][b][color=LIME])[/color][/b]
                       '[b][color=LIME]([/color][/b][b][color=SILVER]([/color][/b]50 . 0.0[b][color=SILVER])[/color][/b][b][color=SILVER]([/color][/b]41 . 1.0[b][color=SILVER])[/color][/b][b][color=SILVER]([/color][/b]51 . 0.0[b][color=SILVER])[/color][/b][b][color=LIME])[/color][/b]
                       [b][color=LIME]([/color][/b]list [b][color=SILVER]([/color][/b]cons 7 [b][color=YELLOW]([/color][/b]cond [b][color=WHITE]([/color][/b][b][color=BLACK]([/color][/b]cdr [b][color=FUCHSIA]([/color][/b]assoc 7 x[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b][b][color=WHITE])[/color][/b] [b][color=WHITE]([/color][/b][color=#2f4f4f]"Standard"[/color][b][color=WHITE])[/color][/b][b][color=YELLOW])[/color][/b][b][color=SILVER])[/color][/b][b][color=LIME])[/color][/b]
                       '[b][color=LIME]([/color][/b][b][color=SILVER]([/color][/b]71 . 0[b][color=SILVER])[/color][/b][b][color=SILVER]([/color][/b]72 . 1[b][color=SILVER])[/color][/b][b][color=LIME])[/color][/b]
                       [b][color=LIME]([/color][/b]list [b][color=SILVER]([/color][/b]cons 11 pt11[b][color=SILVER])[/color][/b][b][color=LIME])[/color][/b]
                       '[b][color=LIME]([/color][/b][b][color=SILVER]([/color][/b]210 0.0 0.0 1.0[b][color=SILVER])[/color][/b][b][color=SILVER]([/color][/b]100 . [color=#2f4f4f]"AcDbAttribute"[/color][b][color=SILVER])[/color][/b][b][color=SILVER]([/color][/b]280 . 0[b][color=SILVER])[/color][/b][b][color=LIME])[/color][/b] [b][color=LIME]([/color][/b]list [b][color=SILVER]([/color][/b]assoc 2 x[b][color=SILVER])[/color][/b][b][color=LIME])[/color][/b] '[b][color=LIME]([/color][/b][b][color=SILVER]([/color][/b]70 . 0[b][color=SILVER])[/color][/b][b][color=SILVER]([/color][/b]73 . 0[b][color=SILVER])[/color][/b][b][color=SILVER]([/color][/b]74 . 2[b][color=SILVER])[/color][/b][b][color=SILVER]([/color][/b]280 . 1[b][color=SILVER])[/color][/b][b][color=LIME])[/color][/b]
                     [b][color=AQUA])[/color][/b][color=#8b4513]; append[/color]
                   [b][color=GRAY])[/color][/b][color=#8b4513]; lambda [b][color=GRAY]([/color][/b]x[b][color=GRAY])[/color][/b][/color]
                 [b][color=OLIVE])[/color][/b][color=#8b4513]; function[/color]
                 atts
               [b][color=TEAL])[/color][/b][color=#8b4513]; mapcar[/color]
             [b][color=PURPLE])[/color][/b][color=#8b4513]; if atts[/color]
             [b][color=PURPLE]([/color][/b]list [b][color=TEAL]([/color][/b]append '[b][color=OLIVE]([/color][/b][b][color=GRAY]([/color][/b]0 . [color=#2f4f4f]"SEQEND"[/color][b][color=GRAY])[/color][/b][b][color=GRAY]([/color][/b]100 . [color=#2f4f4f]"AcDbEntity"[/color][b][color=GRAY])[/color][/b][b][color=GRAY]([/color][/b]67 . 0[b][color=GRAY])[/color][/b][b][color=OLIVE])[/color][/b] [b][color=OLIVE]([/color][/b]list [b][color=GRAY]([/color][/b]cons 410 spc[b][color=GRAY])[/color][/b][b][color=OLIVE])[/color][/b] '[b][color=OLIVE]([/color][/b][b][color=GRAY]([/color][/b]8 . [color=#2f4f4f]"0"[/color][b][color=GRAY])[/color][/b][b][color=OLIVE])[/color][/b] [b][color=TEAL])[/color][/b][b][color=PURPLE])[/color][/b]
           [b][color=RED])[/color][/b][color=#8b4513]; append[/color]
         [b][color=BLUE])[/color][/b][color=#8b4513]; mapcar[/color]
       [b][color=GREEN])[/color][/b][color=#8b4513]; setq r[/color]
       [b][color=GREEN]([/color][/b] [b][color=BLUE]([/color][/b]lambda [b][color=RED]([/color][/b] c / [b][color=RED])[/color][/b] [b][color=RED]([/color][/b]setvar 'cmdecho 0[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]if acet-attsync [b][color=PURPLE]([/color][/b]acet-attsync nm[b][color=PURPLE])[/color][/b] [b][color=PURPLE]([/color][/b]vl-cmdf [color=#2f4f4f]"_.ATTSYNC"[/color] [color=#2f4f4f]"_N"[/color] nm[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b]setvar 'cmdecho c[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]getvar 'cmdecho[b][color=BLUE])[/color][/b] [b][color=GREEN])[/color][/b]
     [b][color=MAROON])[/color][/b][color=#8b4513]; if[/color]
     r
   [b][color=NAVY])[/color][/b][color=#8b4513]; [b][color=NAVY]([/color][/b]tblsearch [color=#2f4f4f]"BLOCK"[/color] nm[b][color=NAVY])[/color][/b][/color]
 [b][color=FUCHSIA])[/color][/b][color=#8b4513]; cond[/color]
[b][color=BLACK])[/color][/b][color=#8b4513]; defun VanillaINSERT[/color]
Might be handy for the guys without activex. o:)
very Nice stuff ronjonp. Thankyou for preparing. small doubt, if i change circle radius to "0.24" and text height to "0.2" (For "meters units" drawing) how to edit your code? please guide me:)
Thank you!!
Hi Grrr friend...thank you for making. how to use your code? what is the command to operate? sorry for asking:)
Thank you!!
                 atts
     r
Nice job! :thumbsup:
Thank you!!
Updated the code above .. will scale correctly assuming the measurement variable is set correctly.
