LosGirk Posted November 16, 2017 Share Posted November 16, 2017 What does the & symbol in front of a DCL label do? example: label = "&Exit Program"; I forgot! Hopefully someone knows quick like off the top of their head; Thank you! Quote Link to comment Share on other sites More sharing options...
rlx Posted November 16, 2017 Share Posted November 16, 2017 https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2015/ENU/AutoCAD-AutoLISP/files/GUID-1D855150-4635-4F6B-B277-28C7EF21B939-htm.html Any character in a label string that is preceded by an ampersand (&) becomes the mnemonic. The character doesn't have to be unique to the dialog box. If more than one tile has the same mnemonic, the user presses that key to cycle through the tiles sequentially. Mnemonics change focus but do not select a tile. If the user specifies a mnemonic key for a tile that contains a group of items, such as a cluster or a list box, the focus is put on the first item in the tile that is a tab stop Quote Link to comment Share on other sites More sharing options...
LosGirk Posted November 16, 2017 Author Share Posted November 16, 2017 Thank you sir. Quote Link to comment Share on other sites More sharing options...
