change all z of point to 0.0
new_mem
You can do this without a lisp by simply selecting all of the points in Top view, and in Properties set the Z values (which will indicate Varies) to 0.0
None of the entities in the dwg are coplanar with the XY plane of the WCS.
You can try this:
Set the UCS to the WCS (_UCS > _World) and then use the _Flatten command.
Hi,
Flatten done then object run to another location.
I mean write code lisp following but ellip not effect:
(defun c:test  ()
 (setq ss (ssget '((0 . "ARC"))))
 (setq n 0)
 (repeat (sslength ss)
   (setq arc (vlax-ename->vla-object (ssname ss n)))
   (setq str (vlax-get arc 'StartPoint))
   (setq end (vlax-get arc 'EndPoint))
   (setq cen (vlax-get arc 'Center))
   (setq str_n (list (car str) (cadr str) 0.0))
   (setq end_n (list (car end) (cadr end) 0.0))
   (setq cen_n (list (car cen) (cadr cen) 0.0))
   (command "_ARC" "C" "_none" cen_n "_none" str_n "_none" end_n)
   (vla-delete arc)
   (setq n (1+ n))
Maybe I have misunderstood, but how do you propose to change the Z coordinates of entities without moving them?
Notice that the normal of most entities is (0.00684151 -7.95332e-005 0.999977) instead of (0 0 1). So everything is slightly tilted relative to the XY plane of the WCS.
Your drawing is very peculiar. Not only are there undesirable 3D effects, the elliptical arcs all seem to have a major and minor radius that is almost equal (in other words: they are virtually circular).
With that in mind here is a function, similar to your suggestion, to create arc replacements in the Z=0 plane for both the arcs and the elliptical arcs:
(vl-load-com)
(defun c:Test  ( / enm idx ss)
 (setq doc (vla-get-activedocument (vlax-get-acad-object)))
 (vla-endundomark doc)
 (vla-startundomark doc)
 (setvar 'cmdecho 0)
 (if (setq ss (ssget '((0 . "ARC,ELLIPSE"))))
   (repeat (setq idx (sslength ss))
     (setq enm (ssname ss (setq idx (1- idx))))
     (if (not (vlax-curve-isclosed enm))
         (command
           "_.arc"
           "_non"
           (mapcar '* (vlax-curve-getstartpoint enm) '(1.0 1.0 0.0))
           "_non"
           (mapcar
             (vlax-curve-getpointatdist
               enm
               (* 0.5 (vlax-curve-getdistatparam enm (vlax-curve-getendparam enm)))
             '(1.0 1.0 0.0)
           "_non"
           (mapcar '* (vlax-curve-getendpoint enm) '(1.0 1.0 0.0))
         (entdel enm)
 (setvar 'cmdecho 1)
The procedure would be:
1. Switch to the WCS.
2. Substitute all (elliptical) arcs using c:Test.
3. Flatten all polylines.
4. Use the _Join command.
5. Some elements will not join to form closed polylines. This is due to inaccuracies.
(vl-load-com)
 (setvar 'cmdecho 0)
         (command
           "_.arc"
           "_non"
           "_non"
           (mapcar
               enm
             '(1.0 1.0 0.0)
           "_non"
         (entdel enm)
 (setvar 'cmdecho 1)
Yep, that is what i said.
Thank you very much Roy. :D
But in my test drawing the ellip RED error. Why ?
In BricsCAD this ellipse is replaced successfully. My guess is that the huge coordinates and the very small difference between the StartAngle and EndAngle are causing a problem in AutoCAD: The arc is almost a straight line. You can try improving the c:Test function to account for this specific case.
The BIG question is of course who or what process produced this cr*ppy drawing?:twisted:
Thanks for suggestion, Roy.
This drawing following from consultant. Crazy!
Xr-Pool.dwg
