nicolas Posted November 19, 2017 Share Posted November 19, 2017 Hi, I have to draw a 45 degree bevel in Inventor 2015. I have been able to do it in spite of many errors displayed. However there are three things that I neeed to do: 1. The overall size of both gear (the outside or addendum circle) need to be 20mm. 2. I need to be able to separate the two gear 3. To animate them Any help or guidance will be greatly appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted November 21, 2017 Share Posted November 21, 2017 Can you attach your assembly here? Quote Link to comment Share on other sites More sharing options...
nicolas Posted November 29, 2017 Author Share Posted November 29, 2017 Hi, Using normal upload is not working as it seemed that cadtutor does not accept iam file. Please use the following link from dropbox. https://www.dropbox.com/s/1cehu8tnrv53wxx/BevelGear.iam?dl=0 I have designed it using the designaccelerator/bevel gear dialogue box. Thanks. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted November 29, 2017 Share Posted November 29, 2017 Right click on the folder and select Sent to Compressed(zipped) folder. Attach the resulting *.zip file here. Are you aware that an assembly must have parts? Quote Link to comment Share on other sites More sharing options...
