Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Junior Member
    nasoox's Computer Details
    Windows 7
    AMD Athlon X250 Dual core 3 Ghz
    4Gb DDR3
    Radeon HD5670 1Gb
    Sata II 500 Gb
    Aoc F22
    Surveying
    nasoox's Discipline Details
    Surveyor
    Surveying
    Underground mine surveyor
    AutoCAD 2013
    Jun 2014
    Serbia
    22
    Default Loft-ing a constant shape
    How to loft two or one profile with guide lines with this rules:
    -Loft will follow 4 guide lines, one guide conect left side of one profile to the left side etc. with one guide per side.
    -Guide lines don't need to connect profiles at same spots but need to connect them at same sides.
    -Edited : Loft will not make 'bumps' but will stretch profile so horizontal lines from profile will stay horizontal and vertical will stay vertical.
    What command or software can doo that? (Vanila Auto CAD, Civil, Electical, Microsoft paint, doesnt matter what software)
    Thank you
    Drawing1.dwg
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,833
    What are you trying to create that requires the three criteria you have set forth for your "perfect" Loft command?
    Junior Member
    Windows 7
    4Gb DDR3
    Radeon HD5670 1Gb
    Sata II 500 Gb
    Aoc F22
    Surveying
    Surveyor
    Surveying
    AutoCAD 2013
    Jun 2014
    Serbia
    22
    Its a 3d representation of underground tunnel (like tunel for traffic) from survey points for walls, roof and floor. It have constant shape , but different width, height and orientation, i need to stretch profile (not scale, sry, error) to touch and follow gude lines.
    I edited main question and I make one sketch of what I need.
    Senior Member lrm's Avatar
    lrm's Computer Details
    Windows 7 64-bit
    16 GB
    Education
    lrm's Discipline Details
    Teacher, AEC and mechanical
    Education
    Civil and Mechanical
    3ds Max 2017
    Jan 2010
    Massachusetts, USA
    371
    Create one master profile for the first section. Make copies of it at the end of the tunnel and anywhere else you want. Create a guide if necessary (e.g., if you only have a start and end profile). Modify the copied profile as necessary without changing the basic topology of the shape. By modifying a copy of the master profile you are assured that the shape will loft "nicely".
    The yellow shape was created with AutoCAD loft between 4 profiles. The green with two profiles and a guide.
  5. #5
    Junior Member
    Windows 7
    4Gb DDR3
    Radeon HD5670 1Gb
    Sata II 500 Gb
    Aoc F22
    Surveying
    Surveyor
    Surveying
    AutoCAD 2013
    Jun 2014
    Serbia
    22
    Thank you for your reply, so you basically say that its impossible for cad to know that it needs to scale profile between guides, so I need to modify and insert profiles at each change (and that is tedious job as hell)
  6. #6
    Windows 7 64-bit
    16 GB
    Education
    Education
    3ds Max 2017
    Jan 2010
    Massachusetts, USA
    371
    I don't think I used the word "impossible" although some things are. Some users are looking for a "read my mind" mode which I have found to be quite difficult to implement. You may be able to use a few profiles and a good guide spline to get the results you need. Without seeing more specifics about what you are trying to do it is impossible to say.
    ~Lee
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,833
    A 3D scan of the tunnel would give you a point cloud to work with wouldn't it? No need to create and loft profiles or somehow come up with "smart" guides.
  8. #8
    Junior Member
    Windows 7
    4Gb DDR3
    Radeon HD5670 1Gb
    Sata II 500 Gb
    Aoc F22
    Surveying
    Surveyor
    Surveying
    AutoCAD 2013
    Jun 2014
    Serbia
    22
    Unfortunately, 3D scaners are extremely expensive, and they wont benefit us nothing that we need for working except it would look pretty. I will upload now in main thread one dwg file with example of our survey with couple of lines just to represent how it look in 3D.
  9. #9
    Junior Member
    Windows 7
    4Gb DDR3
    Radeon HD5670 1Gb
    Sata II 500 Gb
    Aoc F22
    Surveying
    Surveyor
    Surveying
    AutoCAD 2013
    Jun 2014
    Serbia
    22
    I uploaded one dwg file in main post with example of our survey, i drew couple of lines to represent how ceiling and floor would look like, while spline represents vertical walls. I would like to know if its possible to do that with this kind of information cause its impossible to survey edges (ceiling edges are completely irregular and floor ones are covered with rocks and other materials), and if possible how to do it or just to get directions where to search. Im tired of looking at commercials with nice looking projects (simple extrusions of nice looking shapes and all mining software presents mines like that) cause thats what they are, just projects with no real world data.
  10. #10
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,398
    Doing a tunnel this may be one approach you can string all the survey points along the tunnel based on xyz and a code for each string like leftfloor rightfloor. You can create surfaces of the tunnel from Civ3d or similar tubes are not directly supported so make maybe 2-3 surfaces bottom top etc. cross sections could be cut then. Making 3dfaces is feasible but I am sure there will be something already out there.
    But the other way would be to treat the points as a cloud data set and see how Civ3d handles the tube.
    No cad at moment.
  1. does cad 2009 constant freeze up on you????
    By MikeP in forum AutoCAD General
    Last Post: 18th Jun 2012, 03:15 pm
  2. Constant Problems Finding Shape and Font Files
    By rawbass in forum AutoCAD General
    Last Post: 13th Sep 2010, 07:59 am
  3. constant measurments??
    By areejo0o in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 9th May 2010, 01:52 pm
  4. How do you draw a shape on the Z axis using the shape tool?
    By cvriv.charles in forum AutoCAD 3D Modelling & Rendering
    Last Post: 22nd Feb 2009, 10:47 am
