Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 28
  1. #11
    Full Member
    AutoCAD 2014
    May 2014
    91
    How to extrude the profile?
    Is it extruding the profile using the radius line as the path as shown in #8?
  2. #12
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,015
    I am sure Remark will add more detail, you draw your profile say in same plane as the two circles add a line from outer circle to centre, place your profile at this intersection point, move it inwards a bit. Using rotate3D you rotate the profile 90degrees using say the Y option and 90. (Profile is on left side) type -vpoint 1,1,1 and you should see your profile standing up, use extrude as posted by Remark extending past the outer circle. Follow the steps above.
    It sounds like you should practice some of the basic commands extrude subtract union push/pull rotate3D and importantly setting UCS,s .
    Sent from iPad so no pretty pictures.
  3. #13
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,622
    Quote Originally Posted by basty View Post
    What is a "ridge"?
    Please explain with an image.
    See the image in post #9. Those "bumps" are what I am referring to as ridges. This is not my field of expertise so I am not aware of the correct terminology.
  4. #14
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,622
    Extrude the profile using the Extrude command. It has to be extruded enough such that it will extend beyond both the O.D. and I.D. of the ring. To achieve this move the profile slightly outside of the O.D. then extrude inward.
  5. #15
    Full Member
    AutoCAD 2014
    May 2014
    91
    The only thing I can do is to draw the profile. Your explanation on 3D operation is hard to understand. So, please re-explain it step-by-step like:
    step 1: ...
    step 2: ...
    step 3: ...
    and so on.
    How about the ID is 10 and the OD is 12, the amount of profile is 5.
  6. #16
    Senior Member
    AutoCAD 2008
    Oct 2003
    Germany
    288
    Only for information:
    http://www.cadtutor.net/forum/showth...e-a-bottle-cap
    Regards
    Jochen
  7. #17
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,622
    step 1: ...
    step 2: ...
    step 3: ...
    and so on.
    The two images in post #8 visually show what I have been talking about.
    You have to locate your profile relative to the O.D. of the spacer then extrude it before it can be trimmed. Do you at least know how to do that?
  8. #18
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,622
    "How about the ID is 10 and the OD is 12, the amount of profile is 5."
    Are these metric or imperial dimensions? Either way they don't seem right. It's like you are guessing. How many ridges total?
  9. #19
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,622
    Profile located relative to O.D. of spacer. Profile is magenta colored. The O.D. is color green; I.D. is color yellow. The red line is used as a reference point and is drawn from the center of the circles through a quadrant point and then beyond it by a distance of 0.2.
  10. #20
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,622
    Profile is extruded such that it extends beyond the I.D. For reference the distance between the O.D. and I.D. is 0.2 and I extruded the profile an additional 0.2 for an overall length of 0.6.
  1. O-ring groove
    By paulmcz in forum AutoCAD 3D Modelling & Rendering
    Last Post: 5th Mar 2015, 06:24 pm
  2. Ring beam
    By KTS in forum Architecture & ADT
    Last Post: 1st Aug 2013, 12:57 am
  3. Ring Mate
    By slide in forum SolidWorks
    Last Post: 16th Jan 2010, 11:25 pm
  4. Diamond Wedding Ring
    By FazBear in forum AutoCAD 3D Modelling & Rendering
    Last Post: 3rd Aug 2006, 08:33 am
  5. Wedding Ring Templates ??
    By mykemitchell in forum AutoCAD Beginners' Area
    Last Post: 3rd Sep 2003, 09:26 pm
