Page 3 of 3 FirstFirst 1 2 3
Results 21 to 28 of 28
  1. #21
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Trim both circles that form the O.D. and I.D. so you end up with two arcs. Extrude the arcs up and through your extruded profile. These extruded arcs are surfaces that will be used to slice off portions of the extruded profile.
    You will be using the SLICE command with its Surface option to accomplish this task. When executing the SLICE command pay particular attention to the command line and what AutoCAD is both tell and asking you.
    This should be the result.
    Before we can array this however it must be tapered from the O.D. to the I.D.
  2. #22
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Draw two taper lines (cyan colored in image below) from the center of the the arcs to the outside corners of the extruded profile. These will be extruded upwards to slice off the edges of the profile. Again, you will be using the SLICE command with its Surface option to complete this task.
    Taper lines (which are surfaces) extruded through profile.
    Once you have trimmed the extruded profile with the taper lines you can array it. You are familiar with polar arrays are you not?
  3. #23
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Top view of tapered profile before executing a polar array. Visual style is X-ray.
  4. #24
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Final steps. Execute a polar array, explode the array (since it will be a block, then union all the ridges to form a single 3D solid model.
    If after all this you still cannot accomplish the task then perhaps you need to practice with the 3D modeling commands a bit more before attempting to create your spacer ring.
  5. #25
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,127
    I have moved your thread to the AutoCAD 3D Modelling & Rendering Forum, please post in the correct forum.
  6. #26
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,709
    Great tutorial Remark
    For Basty re read my post in particular the use of rotate3D look at Remark's image where the profile is standing vertical compared to the circles.
  7. #27
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    BIGAL: Thank you for your kind words.
    Basty: You can also use the Object option with the SLICE command. You do not necessarily have to extrude the lines and create surfaces.
  8. #28
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    basty: Did you finally figure it out or did you give up?
  1. O-ring groove
    By paulmcz in forum AutoCAD 3D Modelling & Rendering
    Last Post: 5th Mar 2015, 06:24 pm
  2. Ring beam
    By KTS in forum Architecture & ADT
    Last Post: 1st Aug 2013, 12:57 am
  3. Ring Mate
    By slide in forum SolidWorks
    Last Post: 16th Jan 2010, 11:25 pm
  4. Diamond Wedding Ring
    By FazBear in forum AutoCAD 3D Modelling & Rendering
    Last Post: 3rd Aug 2006, 08:33 am
  5. Wedding Ring Templates ??
    By mykemitchell in forum AutoCAD Beginners' Area
    Last Post: 3rd Sep 2003, 09:26 pm
