Results 1 to 3 of 3
    Forum Newbie
    Mechanical
    AutoCAD 2017
    Nov 2017
    2
    Default Convert many small segments of pline into one solid geometry
    Hi!
    I'm new to this forum, but I've got alot of help from you guys when searching for a solution to my problem earlier.
    This time I cant really find what I'm looking for. Hope someone could help me out.
    As the title says, the lines in my attached dxf (the handle) consists of plenty very small segments of plines.
    I want to assemble this dxf with many others to make a complete construction in Fusion 360, but the curved geometry and also the straight lines appears not smooth. Is there any way to make this geometry like one solid line forming the whole geometry?
    Many thanks in advance
    Torcs,
    Norway
    Super Member halam's Avatar
    AutoCAD 2017
    Jul 2015
    658
    There are probably more tools.
    This one set reduces them to by 1/3
    Why don't you just draw a new and better definition?
    Modelling is done with two hands, 2d & 3d. Let it work together..
    https://twitter.com/halammerts
    Forum Newbie
    Mechanical
    AutoCAD 2017
    Nov 2017
    2
    Hi! Thank you for showing me that option! I'll check that out. But the problem is that Fusion 360 has a problem handling the geometry. Lot of lag, maybe because of the vertexes. Of course a pretty fair solution to this is to draw the geometry all from scratch.
    I'm pretty new in using ACAD like this. I just thought it could exist a quick fix for this. But as I understand I'll never get rid of those vertexes.
    Thank you for taking time to answer me on this one,
    Regards,
    Tor Christian
  1. Convert to Solid from 3 profiles of Element; 3dpline, Pline, Spline. How ???
    By Deby Ferdian in forum AutoCAD Drawing Management & Output
    Last Post: 7th May 2016, 11:14 am
  2. Convert 2 x 2D spline/pline to 3D
    By ssredman in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Jun 2014, 06:33 am
  3. Convert Any Length Arc into Equal Segments
    By EricDevault in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Mar 2014, 09:56 pm
  4. Add segments to pline
    By emadageeb in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Jul 2011, 12:34 am
  5. Convert a G-Code into geometry
    By Son of Aslan in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Nov 2010, 06:04 pm
