Results 1 to 3 of 3
    Junior Member
    AutoCAD 2017
    Oct 2017
    19
    Smile Command for repeating an image around a circle?
    Several weeks ago I was using a command in Autocad which meant when I had drawn a large circle, I could place (for example) a small circle within it and near the circumference and then input into CAD the number of times I wanted this repeated around the circle.
    I can't recall what command this was, would be be much appreciated if anyone knows. Thanks!
    Senior Member
    Civil
    Aftertouch's Discipline Details
    Civil
    Engineer
    AutoCAD 2017
    Jul 2016
    Netherlands
    295
    Do you mean ARRAY?
    Junior Member
    AutoCAD 2017
    Oct 2017
    19
    Quote Originally Posted by Aftertouch View Post
    Do you mean ARRAY?
    Yes, that's what it was Aftertouch, thanks. Yes, a polar array.
  1. repeating lisp command
    By salman in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Oct 2017, 12:28 pm
  2. Set repeating lisp command
    By Grrr in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Apr 2014, 12:41 pm
  3. Help-Repeating the Offset command
    By Excalibur Shane in forum AutoCAD Beginners' Area
    Last Post: 22nd Feb 2012, 07:19 am
  4. help on cond and repeating command
    By Lt Dan's legs in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Aug 2010, 08:13 pm
  5. Repeating a command on different files, ...ehm??
    By MarcoW in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Apr 2010, 04:58 pm
