AdamW Posted November 26, 2017 Share Posted November 26, 2017 Hello Does anyone have a solution or work around to the following. I was recently upgraded to windows 10 from 7 but still using AutoCAD 2015. Now when i hold the shift key down it no longer changes the ortho lock. The AutoCAD forum suggests changing the tempoverrides variable, but alas this does not work. Others say it Windows 10 causing the problem. I am unable to downgrade to 7 as it is a works machine. Thanks Quote Link to comment Share on other sites More sharing options...
SLW210 Posted November 27, 2017 Share Posted November 27, 2017 I have moved your thread to the AutoCAD Bugs, Error Messages & Quirks Forum. Windows 10 would be my guess, as well, you should contact IT and inform them of the difficulties encountered since the move to Windows 10. An upgrade to AutoCAD would be the best solution IMHO, to see if it is indeed AutoCAD 2015 on Windows 10 you could try a free trial of AutoCAD 2018 and see if the problem goes away. Quote Link to comment Share on other sites More sharing options...
