Results 1 to 7 of 7
    Senior Member Squirltech's Avatar
    Squirltech's Computer Details
    Windows 7 Enterprise, Service Pack 1
    BOXX
    32.0 GB
    230 GB
    Single DELL 34" Curved
    Surveying
    Squirltech's Discipline Details
    Project Coordinator
    Surveying
    Civil 3D 2018
    Oct 2010
    30 15' N, 97 44' W
    272
    Default Best way to achieve
    Howdy everyone! Hope everybody had a nice holiday weekend and that everyone is doing well.
    I'm needing some assistance with figuring out the best way to achieve the end result for a technician here in our office.
    Here's the thing, we do elevation certifications for landfills and we have to label the "cover", "clay" and "subgrade" then show the difference between the cover and clay and the difference between the clay and subgrade. At this point, it is all hand entered information at each location (100s per area). The previous technician (no longer employed here) was using a block with attributes and hand entering the elevations then doing the math manually.
    The question is, is there a way to do the math auto-magically? I'm not sure there's a way around hand entering, at least part of, the information required. I've attached a drawing of the existing block with attributes for reference. Any help is greatly appreciated!
    ElevCert_DynBlk.dwg
    T. Nelson - Project Coordinator
    http://www.sam.biz/
    "The only thing left to do is EVERYTHING!" - Jesse James
    "Work smarter, not harder" - Unknown
    BOXX
    32.0 GB
    230 GB
    Surveying
    Project Coordinator
    Surveying
    Civil 3D 2018
    Oct 2010
    30 15' N, 97 44' W
    272
    Ok...so I've figured out how to do the math auto-magically BUT I've heard of a way to "insert a REGEN" into the field so the values populate. Am I misunderstanding the phrase "insert a REGEN"? If that's just a way of saying, REGEN your drawing, then I've got this. Otherwise, please explain.
    Also, if anyone has a better way of doing this overall step, I'm all ears.....well, and feet.
    http://www.sam.biz/
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,769
    The command you may be looking for is ATTSYNC. The block needs to be selected and then the command issued. You may need some code, and I don't know how to do that.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,595
    You have not mentioned how you get the 3 values to start with.
    Ok my $0.05 I have 3 surfaces drop a point on each surface ie 3points it auto assigns a Z a function of CIV3d, just get each points detail as you make the point 3 z's so just fill in your block now placed at the point with the correct z1-z2 z2-z3 etc
    Post a dwg with some more actual detail ie some z stuff to get a better idea of what your actually doing.
  5. #5
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,209
    With Civil3D and some data you should be able to build three surfaces, as Big Al says. There is a surface property that lets you define a grid with X and Y for each component. You can then create two volume surfaces to calculate the differences for each grid component (I assume that's what the blocks are for). You can print the grid with a volume label in each component. QED I guess. Make sure you set your compaction adjustment to zero (unless there's a value you're supposed to use).
    breaking AutoCAD on a regular basis since 1991
  6. #6
    BOXX
    32.0 GB
    230 GB
    Surveying
    Project Coordinator
    Surveying
    Civil 3D 2018
    Oct 2010
    30 15' N, 97 44' W
    272
    The three elevations on the left are hand entered based on the existing conditions (SG), elevations collected on the clay added to bury the trash (CLAY), and dirt cover to bury it all (Cover) based on design elevations.
    There is only a single surface and the multiple surfaces are adding a lot more difficulty than what I'm looking for.
    In short, I want a dynamic block that takes the three hand entered elevations and does the math automatically (with a regen) to populate the two "numbers" on the right. Using MTEXT and FIELDS I can get it to work but the moment I make it a block with attributes, the math and formulas don't work.
    http://www.sam.biz/
  7. #7
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,595
    If hand entered then the proceedure is
    enter Z1
    enter Z2
    Enter z3
    H1= z2-z1
    h2 = z3-z2
    insert block pt 1 1 0 h1 h2
    Just do the maths and create the block as you type in the values it does not make sense to type in the values then do some maths on the result
    Code:
    (defun c:elevblk ( / val1 val2 val3 h1 h2)
    (if (not ah:getval3)(load "getvals3"))
    (setq val1 "1") ; dummy line to start
    (while (/=  val1 "0.0")
    (ah:getval3 "Enter 1st Z value" 5 4 "0.0" "Enter 2nd Z value"5 4  "0.0" "Enter 3rd Z value" 5 4 "0.0")
    (setq h1 (- (atof val2) (atof val1)))
    (setq h2 (- (atof val3) (atof val2)))
    (if (/= val1 "0.0")
    (setq pt (getpoint "\nPick insertion pt"))
    (command "-insert" "CERT-ELEV" pt 1 1 45 (atof val1) (atof val2) (atof val3) h1 h2)
  1. Lisp idea not sure how to achieve
    By gunther in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Mar 2013, 04:29 pm
  2. Which Table Formula will work to achieve this result?
    By colors in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 14th May 2012, 05:30 pm
  3. 3D extruded model adjustment - can't achieve ...
    By JimB in forum AutoCAD Drawing Management & Output
    Last Post: 6th Jan 2011, 07:05 pm
  4. How to achieve this function ?
    By xcuiwu in forum AutoCAD Beginners' Area
    Last Post: 23rd Jun 2008, 11:54 pm
  5. Trying to achieve a 60" plot
    By Cyclopean in forum AutoCAD Beginners' Area
    Last Post: 14th Jan 2003, 07:02 am
