Results 1 to 8 of 8
    Forum Newbie
    Landscape
    AutoCAD 2016
    Nov 2017
    2
    Default Need Help about Auto Printing
    Hello everyone.
    I have a model with lots of sheets in it. I want to print all of them in order but printing them manually by selecting every paper as print screen is waste of time.
    I just want to speed up this progress. I read some other topics but coudn't understand what to do. I look some guides about ploting but coudn't find answers about my problems. At least someone can guide me to documents I have to look for auto printing those papers please?
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    I'm guessing all of your "sheets" are in model space because you don't know how to make use of layouts. Is that correct?
    Forum Newbie
    Landscape
    AutoCAD 2016
    Nov 2017
    2
    Hello ReMark, yes unfortunately all my sheets are in one model space. 200 set(400 page total) and yes I didn't use layouts before :/
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    As I figured. There have been other threads posted with this exact same problem but off the top of my head I can't point you at any particular one. Try a search.
  5. #5
    Senior Member
    Civil
    Aftertouch's Discipline Details
    Civil
    Engineer
    AutoCAD 2017
    Jul 2016
    Netherlands
    304
    This will do the trick for your DWG.
    VERY QUICK AND DIRTY CODE!!
    Code:
    (defun C:CADTUTOR ( / )
    (setq ss (ssget "_X" (list (cons 410 "Model"))))
    (sssetfirst nil ss)
    (command "PEDIT" "M" "P" "" "Y" "" "J" "" "")
    (setq ss (ssget "_X" (list (cons 8 "0")(cons 410 "Model"))))
    (sssetfirst nil ss)
    (command "PEDIT" "M" "P" "" "C" "")
    (setq n 0)
    	(repeat (sslength ss)
    		(setq ensel (ssname ss n))
    		(setq ensellength (vlax-curve-getdistatparam ensel (vlax-curve-getendparam ensel)))
    			(if (= (fix ensellength) 14100 )
    				(setq newlist (cons ensel newlist))
    		(setq n (+ n 1))
    	(setq n 0)
    	(repeat (length newlist)
    		(setq ensel (nth n newlist))
    		(setq enlist (entget ensel))
    		(setq lowerleft (cdr (assoc 10 enlist)))
    		(setq upperright (cdr (nth 24 enlist)))
    			(command "-PLOT" "Y" "" "DWG TO PDF" "A3" "M" "P" "N" "W" lowerleft upperright "F" "C" "Y" "" "Y" "" n "N" "Y")
    		(setq n (+ n 1))
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Here is another solution I found at the AutoDesk website. Refer to post 6 of 7 by forum member "3wood".
    https://forums.autodesk.com/t5/autoc...561096#6259970
  7. #7
    Senior Member
    AutoCAD 2009
    Oct 2012
    342
    No problem.
    We print quickly and easily.
    For batch printing from the model, there is a program:
    https://www.kdmsoft.net/revers.html
    Here is the image after processing, ready to print 40 pages :
  8. #8
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    Here is another but the maratovich solution is a more universal rather than hard coded like this.
    You will need to change the title block name and the sheet sizes
    Code:
     (PROMPT ".....PRINTING DRAWING TO plotter....")
    (setq oldsnap (getvar "osmode"))
    (setvar "osmode" 0)
    (setq ss2 (ssget "x" '((0 . "INSERT")(2 . "Title block name")(410 . "Model"))))
    (setq n (sslength ss2))
    (setq index 0)
    (repeat n
        (setq en (ssname ss2 index))
        (setq el (entget en))
        (setq inspt (assoc 10 el)) ; insertion pt
       (setq xmin (- (cadr inspt) 6.0))
       (setq ymin (- (caddr inspt) 6.0))
       (setq xymin (strcat (rtos xmin 2 1) "," (rtos ymin 2 1)))
       (setq xmax (+ xmin 813.0)) ; hard coded for 813 wide 6mm offset
       (setq ymax (+ ymin 566.0)) ; hard coded for 566 high
       (setq xymax (strcat (rtos xmax 2 1) "," (rtos ymax 2 1)))
      (COMMAND "-PLOT"  "Y"     "" "//PRxxxxx/Design-5100"
    	       "A3"	"M"     "LANDSCAPE"   "N"
    	       "W"	  xymin   xymax "1=2"  "C"
    	       "y"	  "Designlaser.ctb"      "Y"   ""	"n"   "n"
    	       "y"
      (setq index (+ index 1))
    (setvar "osmode" oldsnap)
    It is feasible to create layout tabs moving the title block to a layout and using a mview of the objects still in model space. That would allow you to use Publish or in my case my own version of publish.
  1. auto lisp programme for selected line's length table in auto cad 2014
    By MAD in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Jun 2017, 03:34 am
  2. auto cad printing problems
    By afrazawan in forum AutoCAD Drawing Management & Output
    Last Post: 27th Jan 2014, 01:11 pm
  3. Replies: 6
    Last Post: 20th Sep 2011, 07:39 am
  4. What is key TERRA FIRMA in auto cad & how we use it in auto cad
    By tariq mahmood in forum AutoCAD General
    Last Post: 9th Jan 2009, 12:39 pm
  5. Viewport Not printing-only layout printing
    By rambala1234 in forum AutoCAD General
    Last Post: 19th Sep 2008, 02:28 pm
