Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
    Full Member
    AutoCAD 2010
    Jul 2009
    38
    Default Not Able to Copy Paste any of the objects in drawings
    Hi,
    I am not able to Copy Paste any of the objects in attached drawing.
    new block.dwg
    Errors as follows-
    *Warning* Multiply owned object, handle "27"
    pasteblock Duplicate definition of block _ArchTick ignored.
    INTERNAL ERROR: !dbdxfout.cpp@874: eNotThatKindOfClass
    Tried dxfout command, gived fatal error
    Tried (entdel(handent "27")) , No success
    tried Purge, insert and wblock commands , no success
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Is this the error you are referring to?
    *Warning* Multiply owned object, handle "23"
    I see via Audit that you also have a bad linetype. $AUDIT_BAD_LTYPE7
    What is the source of the block?
    Full Member
    AutoCAD 2010
    Jul 2009
    38
    This is received from our Client. How can we get rid of this bad linetupe??
    Not even able to use qselect tool, gives fatal error....any suggestions??
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    What program did your client use to create the block?
  5. #5
    Full Member
    AutoCAD 2010
    Jul 2009
    38
    Not Sure....The package contains some revit files as well...Client might have exported from revit & then further modified in AutoCAD.
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Please do not double post. It just causes confusion and splits responses between threads making it difficult to follow the course of the conversation.
  7. #7
    Full Member
    AutoCAD 2010
    Jul 2009
    38
    Sure, noted...Not able to reach client. Does anyone has answer to this...?
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    I have been unsuccessful in multiple attempts. I suggest you either redraw the block yourself or make a more determined effort to reach the client.
  9. #9
    Full Member
    AutoCAD 2010
    Jul 2009
    38
    What I send you is just an extract from the drawing, I have several such drawings. I have attached one full drawing in below link for you, if it helps-
    Download link
    https://we.tl/4n5XJHjOf4
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Are you telling us that the problem exists in all the drawings you received from your client? If that is the case then it is doubly important you contact the client.
  1. Cannot copy and paste between drawings
    By KRENG in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 17th Nov 2017, 12:27 am
  2. Can't Copy and Paste Between Drawings
    By WireGuy1950 in forum AutoCAD Drawing Management & Output
    Last Post: 20th Sep 2012, 04:41 am
  3. Copy between drawings without using Cut & Paste
    By CAD Panacea in forum AutoCAD RSS Feeds
    Last Post: 7th Feb 2012, 08:00 pm
  4. Replies: 2
    Last Post: 12th Jun 2010, 04:30 pm
  5. Unable to copy and paste between drawings
    By Russell H in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 13th Mar 2008, 12:55 pm
Tags for this Thread
