Results 1 to 8 of 8
    Junior Member
    Civil
    AutoCAD LT 2018
    Nov 2017
    14
    Default Quick question Connect arc and line
    Hi all
    I was just wondering if someone could shed some light on what is the best way to draw an arc between a set arc and a straight line. The straight line is adjustable in length, but orientation is set. Likewise ideally the existing arc is set in length and orientation.
    Therefore I would like to fit a new arc between the two.
    Thanking you In advance!
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,400
    Post an image or a dwg to explain more if Fillet does not work, known problem with Autocad, use Circle TTR.
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,118
    Is the joining arc of known radius?
    A picture (or drawing) of what you are trying to do would be an immense help.
    Junior Member
    Civil
    AutoCAD LT 2018
    Nov 2017
    14
    I was trying to upload something fellas but it just wont work from imgur! arghh
  5. #5
    Junior Member
    Civil
    AutoCAD LT 2018
    Nov 2017
    14
  6. #6
    Junior Member
    Civil
    AutoCAD LT 2018
    Nov 2017
    14
    [IMG][/IMG]
  7. #7
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,118
    Well done for posting an image, but at that scale, both lines look to be straight.
    Perhaps a drawing containing only those two lines would be more useful, and can you show which points are fixed.
  8. #8
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 7 Pro x64
    HP ZBook 17
    i7-4810MQ @ 2.80 GHZ
    16GB
    Nvidia Quadro K4100M
    256GB SSD
    1TB SATA
    (2) HP 23"
    Civil
    rkmcswain's Discipline Details
    Civil
    CAD Manager
    Civil 3D 2017
    Sep 2005
    Houston
    4,511
    The entity on the left looks to be a polyline FWIW.
    OP - If you do not need a true arc, but need a smooth connection, take a look at the BLEND command.
    R.K. McSwain
    CAD Panacea | twitter
  1. New Thread Suggestion: Quick Question, Quick Answer
    By Pintoleite in forum Feedback
    Last Post: 11th Apr 2012, 01:23 pm
  2. new here. Quick question.
    By jdgrant in forum AutoCAD General
    Last Post: 8th Mar 2012, 04:57 pm
  3. Connect point to nearest line
    By felixsauve in forum AutoCAD General
    Last Post: 20th Jun 2010, 09:54 am
  4. quick question
    By allanp in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Oct 2004, 09:04 pm
