Results 1 to 4 of 4
    Full Member
    erratic's Computer Details
    Win 7 x64
    Custom Build
    Intel Xeon CPU E5-1650 v2 @ 3.50GHz
    Envy 32 & Compaq LA2405 WIDE
    HVAC
    erratic's Discipline Details
    CAD Operator/ Manager/ Programmer - HVAC
    HVAC
    MEP 2017
    Dec 2009
    Reno, NV
    86
    Default TABLESTYLE not being applied
    Task: Create a schedule from an excel spreadsheet.
    Tablestyle has been created & looks great when used with "start with empty table". The problem occurs when "create from data link" is used. The information shows up just fine & it lists as the correct tablestyle that has been created but the formatting is lost. From font, to style, to color of text & borders. All gone.
    Creating schedules from scratch is a typical process but with having excel schedules in place its a little different. I probably could have done them the old way by now since a solution to my problem is nowhere to be found.
    Note:
    Attachment shows the desired table style (above) and how it shows up (below)
    Currently running 2017 MEP in windows. Vanilla Cad is not helping either.
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,029
    Can you post a dwg and xls like image above.
    Full Member
    Win 7 x64
    Custom Build
    HVAC
    HVAC
    MEP 2017
    Dec 2009
    Reno, NV
    86
    Quote Originally Posted by BIGAL View Post
    Not sure if this is a software bug or simply a setting that is wrong. Everything seems to be done correctly but the styles are not being applied. A table will have the correct style listed as current but the formatting is not there. In addition, the font used in the text style is not the font used when the table style is applied. The cell will have the correct cell type but not the formatting. Tables can be corrected by re-applying the desired format but once a data update takes place the formatting is lost. Certainly not desirable. The feature is a nice thought but does work correctly.
    Please advise.
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,029
    You are right you can reconfigure the table to your style, but update will change, not something we do but will have a look around.
  1. Can it applied to my cellphone or ipad
    By ellasmoth in forum Revit MEP
    Last Post: 4th Jun 2015, 02:10 pm
  2. Can 3D applied to TV
    By ellasmoth in forum Catch All
    Last Post: 26th May 2015, 05:58 am
  3. Layerstate applied via lisp?
    By jtk07 in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th Feb 2014, 02:19 pm
  4. Delete a Tablestyle
    By ziemerd in forum AutoCAD Beginners' Area
    Last Post: 8th Jun 2011, 12:54 am
  5. Object ID of a tablestyle
    By HofCAD in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Mar 2006, 08:42 pm
Tags for this Thread
