Results 1 to 8 of 8
    Forum Newbie
    Construction
    AutoCAD 2017
    Dec 2017
    1
    Smile Drawing Site Plan in Autocad 2D using Northing and Easting value
    I have details as below
    Line Northing Easting Distance
    1 2 2554942.79 527285.17 37 metrer
    2 3 2554966.41 527313.65 27.37 meter
    5 1 .............
    How to draw these lines please explain.
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,133
    The short answer is to observe the format that AutoCAD uses for coordinates and see if you can use that to draw your points.
    AutoCAD inputs coordinates with an x value in the horizontal direction and a y value in the vertical direction.
    Your data has Northing coordinates, i.e. in the vertical direction and Easting coordinates, i.e.in the horizontal direction.
    So by inputting your coordinates in the order Easting, Northing you will end up with a figure like this.
    Full Member
    hakmawongzi's Computer Details
    MS Windows 10 64 bit
    DELL PRECISION M4500
    Intel Core i7 Q720
    16GB
    Nvidia Quadro FX1800M
    256GB SSD Samsung EVO
    Electrical
    hakmawongzi's Discipline Details
    Low voltage installer
    Electrical
    Telephone, data and cablevision cabling Security alarm system installation CCTV installation Residential low voltage installation
    AutoCAD LT 2011
    Mar 2016
    Vancouver, BC Canada
    33
    Attachment 62741Here is a picture with step by step.
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,581
    Open the data in excel it should come in as columns A B C D E starting at cell A2 need 1st line blank.
    in G1 type PLINE
    in G2 =CONCATENATE(D2,",",C2)
    copy this down for all lines
    in G7 type C
    Just copy the G column data directly to the command line and a pline will be drawn.
    Repeat as required. Look at post above to see the column of text.
  5. #5
    Full Member
    Intel Core i7 Q720
    16GB
    Electrical
    Electrical
    AutoCAD LT 2011
    Mar 2016
    33
    Shouldn't it be D2,",",c2 if we are going to draw Easting first ?
    Seems like a lot of work just to draw a couple of lines.
  6. #6
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,581
    Yes you are right Easting Northing change the Concatenate
    Hakmawongzi your discipline is noted as Electrical trust me we work in real world co-ords every day and those big numbers are a pain if you have to copy and paste them all over the place, forget typing so easy to make mistakes. This type of work is State scrutinised and in our case our Licensed surveyor could lose his practicing license if lots of errors are found. The data no doubt came from a GPS.
  7. #7
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,133
    You have to consider this thread in the context of being an exercise.
    How boring it would be if the exercise was to draw a rectangle 37m by 27.37 m, chamfer the bottom left hand corner 5m by 5m. and then rotate the whole by nearly 40 degrees.
    Instead the exercise makes the student practise reading long strings of digits and then accurately type those in. Then the geometry can be investigated, and shown that none of the cormers that have been placed by coordinates to two decimal places are whole right angles. Also the area is not exactly 1000 sq.m. Also one of the quoted lengths between points 5 and 1 is wrong.
    So the exercise shows how tolerant one has to be in real life, and accuracy is compromised by not using exact geometry. A very valuable exercise, if done properly!
  8. #8
    Full Member
    Intel Core i7 Q720
    16GB
    Electrical
    Electrical
    AutoCAD LT 2011
    Mar 2016
    33
    Quote Originally Posted by BIGAL View Post
    I hear you Bigal. I certainly won't want to input large pool of numbers into AutoCAD if the data is already provided in a tabulated format.
  1. Replies: 3
    Last Post: 26th Jul 2016, 02:12 pm
  2. transfer points Easting ,Northing,Elevation,and Description on excel from autocad
    By anindya in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 25th May 2016, 07:00 am
  3. Gps coordinates (northing & easting)
    By NSSC in forum AutoCAD General
    Last Post: 25th Oct 2012, 01:39 pm
  4. Help: Northing and Easting??
    By tzframpton in forum Civil 3D & LDD
    Last Post: 15th Feb 2011, 02:37 pm
  5. Attributes - Northing/Easting
    By SAM24462 in forum AutoCAD General
    Last Post: 7th Apr 2010, 02:47 pm
Tags for this Thread
