Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Senior Member
    AutoCAD 2010
    Jun 2012
    376
    Default Returning to previous editing screen
    Hi everyone,
    Previously, when I want to open a file in the editor, I am presented with the recent files I have been working on straight away. However, after running a lengthy file of about 2500 lines of code, resulting in a crash, I started getting a Visual Lisp console where I have to select the folder and give type of file before I can select the file. Though the program works fine now, each time I want to make a change I have to go through the same lengthy process.
    How can I prevent this happening?.
    Thanking n advance for a solution.
    Aloy.
    Luminous Being
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    9,901
    There is no doubt some registery entries etc that hold this info but no idea where. Some one more advanced in Regapp may be able to help or else it may be an old fashioned INI file some where.
    had a quick look 1800 INI files none jumped out as relevant.
    Senior Member
    AutoCAD 2010
    Jun 2012
    376
    Thanks Bigal for the try. Will wait for advice from others too. If not was thinking of formatting and reinstalling AutoCAD.
    Luminous Being
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    9,901
    Google for "what files have changed" I am pretty sure that you can record what files are opened and closed etc may give some clues about the VLIde writing the file list.
  5. #5
    Senior Member
    AutoCAD 2010
    Jun 2012
    376
    BIGAL, Fearing virus attacks, I haven't connected my computer to internet. But some virus may have got in via pen drives. Perhaps that may be the reason why it behaves the way it does. Any idea about the files that catches the default settings of the vlisp editor and the way to initialize them at the start of autocad?.
  6. #6
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 7 Pro x64
    HP ZBook 17
    i7-4810MQ @ 2.80 GHZ
    16GB
    Nvidia Quadro K4100M
    256GB SSD
    1TB SATA
    (2) HP 23"
    Civil
    rkmcswain's Discipline Details
    Civil
    CAD Manager
    Civil 3D 2017
    Sep 2005
    Houston
    4,456
    Are you talking about the recent file list, in the File drop down menu of the VLIDE?
    R.K. McSwain
    CAD Panacea | twitter
  7. #7
    Senior Member
    AutoCAD 2010
    Jun 2012
    376
    In the Visual Lisp Editor there is no 'recent files' item in the drop down list of 'File'. How ever previously when you open the editor you go straight to the file you edited last time. I believe at the start of Autocad these default settings are executed. And for some reason this file may have been deleted or corrupted. When this happened for the first time an automatic message asked me to send a report to Autodesk.
  8. #8
    Windows 7 Pro x64
    HP ZBook 17
    16GB
    256GB SSD
    1TB SATA
    (2) HP 23"
    Civil
    Civil
    CAD Manager
    Civil 3D 2017
    Sep 2005
    Houston
    4,456
    Quote Originally Posted by aloy View Post
    Sure there is. File>Reopen>Flyout
    Regardless of that, the condition of the VLIDE is written to disk when AutoCAD successfully closes. If your routine is crashing AutoCAD, then those settings never get saved.
    Try this. Open your file, then shut down AutoCAD gracefully. Then reopen AutoCAD, and then the VLIDE. Does it reappear automatically now?
    R.K. McSwain
  9. #9
    Super Member rlx's Avatar
    rlx's Computer Details
    W10
    i74ghz/ssd500/2tbhdd
    Electrical
    rlx's Discipline Details
    electrical designer dragon
    Electrical
    I dont excel in anything but I rearly give up
    AutoCAD 2016
    Nov 2014
    Bergen op Zoom , Netherlands
    637
    you could also check if your configuration file (VLIDE.DSK) is corrupt :
    http://www.geospecialling.com/index....-more-awesome/
    Of course , you can use backups etc but keeping your files in a easy to reach folder (short path / add to favorites) is less work. But I agree , it can be annoying to have to manually select your files once in a while ...
    gr. R
  10. #10
    Luminous Being
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    9,901
    If you invoke the vlide and close all files when you open next time it will be blank is this what you want ?
  1. Replies: 9
    Last Post: 12th Jan 2016, 01:48 pm
  2. Returning last user variable
    By Andrew1979 in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Jul 2015, 03:42 am
  3. Returning to AutoCad
    By Hugo Skeeter in forum Software & Licensing
    Last Post: 5th Mar 2013, 10:03 pm
  4. Text editing box is off-screen
    By SteveDevil in forum AutoCAD General
    Last Post: 11th Sep 2008, 03:26 pm
  5. Returning after a long absent
    By Hawkeye in forum AutoCAD Drawing Management & Output
    Last Post: 8th Sep 2005, 06:50 am
