+ Reply to Thread
Results 1 to 6 of 6
  1. #1
    Super Member Bill Tillman's Avatar
    Using
    AutoCAD 2018
    Join Date
    Oct 2008
    Location
    Miami, FL
    Posts
    1,299
    Default Trying To Follow Tutorial
    I found this wonderful tutorial on YouTube but try as I might, I cannot get a certain part of it to work as they show it. The presenter draws two perpendicular lines and then trims them to form a 90° corner. This is right around the 4:20 minute point in the video. Then he fillets the lines with an 86.5 mm radius...everything I do works up to this point. But when they OFFSET the three (3) lines, that's when my copy of Inventor goes off the rails. When I click on the OFFSET menu and then try to select the three (3) individual lines as they do, the selection highlights five (5) lines, like it's all joined together. This of course will not let me continue as they present the tutorial. I do not understand. Is there something different in Inventor 2018 which is causing this?
    BTW, this video has a nice, mellow, jazzy background tune which I find much easier to listen to that most tutorials which use acid rock.
    It's deja vu, all over again.
  2. #2
    Senior Member
    Discipline
    Manufacture
    gazza_au's Discipline Details
    Occupation
    Engineering
    Discipline
    Manufacture
    Details
    Management/Stainless Fabrication/Design/Drafting
    Using
    AutoCAD 2015
    Join Date
    Apr 2010
    Location
    Australia
    Posts
    132
    Default
    Seems like a very long winded way of doing things, I would sketch your center-line profile out.
    Then create a plane to sketch your pipe size on.
    click on the plane symbol, click on the end point of your sketch,click the center-line profile.
    now once the sketch plane is created,start another sketch then draw your circles,dimension,finish sketch then sweep your profile along your path.
  3. #3
    Forum Newbie
    Discipline
    Mechanical
    Using
    AutoCAD 2017
    Join Date
    Dec 2017
    Posts
    1
    Default
    I agree that the method is long winded but, to answer the original question, I suspect that you need to select 'offset' then before picking any lines, Rclick & untick 'loop select'. That should let you pick individual lines.
  4. #4
    Using
    AutoCAD 2018
    Join Date
    Oct 2008
    Location
    Miami, FL
    Posts
    1,299
    Default
    I was able to get a little more done with this one but still no cigar. What I'm finding is that when the 43mm lines are present and I try to offset the arc and the other two lines, it keeps grabbing all 5 lines like it's a polyline. No matter how many times I watch it there's nothing I see them doing different than what I'm doing so I'm thinking that it's a setting in my copy of Inventor which groups all 4 lines plus the arc instead of the arc and just the two adjacent lines.
  5. #5
    Senior Member
    Discipline
    Manufacture
    Occupation
    Engineering
    Discipline
    Manufacture
    Details
    Using
    AutoCAD 2015
    Join Date
    Apr 2010
    Location
    Australia
    Posts
    132
    Default
    Sounds like your lines have constraints,what color are all your lines?
    Right click and remove the constraints, if you watch the video he doesn't constrain them until after the offset, then use coincident constraint on the end of the line.
  6. #6
    Luminous Being JD Mather's Avatar
    Using
    Inventor 2015
    Join Date
    Sep 2007
    Location
    Williamsport, PA
    Posts
    8,731
    Default
    Quote Originally Posted by Bill Tillman View Post
    ... it keeps grabbing all 5 lines like it's a polyline.....
    Attach your *.ipt file here and end all doubt.
    Certified SolidWorks Professional
    Autodesk Inventor 2015 Certified Professional
    Autodesk AutoCAD 2013 Certified Professional
Similar Threads
  1. pdf tutorial
    By sivapathasunderam in forum Revit Structure
    Last Post: 15th Jan 2017, 05:35 pm
  2. 2012 Tutorial
    By BillB in forum Autodesk Inventor
    Last Post: 20th Oct 2011, 02:48 pm
  3. Tutorial: Draw a 3D threaded bolt - video tutorial
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 4th Aug 2009, 06:40 am
  4. Tutorial Help
    By Polstar in forum Architecture & ADT
    Last Post: 17th Mar 2009, 10:54 pm
  5. Another New Tutorial
    By CADTutor in forum News, Announcements & FAQ
    Last Post: 15th Oct 2002, 12:43 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
