Results 1 to 8 of 8
    Full Member
    Jozef13's Computer Details
    Win 7
    HVAC
    AutoCAD 2016
    Jun 2015
    Slovakia
    37
    Default Dynamic Block with "Plan Readable" Attribute
    Hello, Could you help me please ?
    I am frustrated with creation of Dynamic Block with "Plan Readable" Attribute.
    I've tried to modify existing block that is also working.
    I am able to create DB with always horizontal attribute but I can not create new one with "Plan Readable" Attribute as you can see in attachment.
    Senior Member
    iconeo's Computer Details
    Windows
    Multi-disciplinary
    iconeo's Discipline Details
    CAD Manager/Draftsman
    Multi-disciplinary
    AutoCAD 2017
    Jun 2007
    Seattle
    306
    You are having trouble trying to replicate the functionality of the other block because you don't have all the pieces. Its not your fault either, I'd call it a bug, but AutoCAD doesn't have bugs right?
    Go into your source block from Libbya, type in BACTIONBARMODE and toggle it to 0. You will see that there are other parts to this block that must be included.
    Thanks.
    Full Member
    Win 7
    HVAC
    AutoCAD 2016
    Jun 2015
    Slovakia
    37
    Quote Originally Posted by iconeo View Post
    Thanks.
    Thank You very much, It is clear now.
    But I am not able to set Lookup range parameter to [0,90],(270,0] but only to [0,90],(270,).
    I am wondering why it is possible in original block but not in my new one.
    Senior Member
    Windows
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2017
    Jun 2007
    Seattle
    306
    Change your degree units accuracy to 0.0000
  5. #5
    Full Member
    Win 7
    HVAC
    AutoCAD 2016
    Jun 2015
    Slovakia
    37
    Units accuracy changed but range parameter [0,90],(270,0] still not possible.
    But if I checked the original block parameter, it has changed to [0,90],(270,359.9999]
    If I use [0,90],(270,359.9999] in my block, it works fine as well.
    Is it wrong if I use (270,) for everything greater than 270 ? In fact, greater could be only 360 if I consider degrees.
  6. #6
    Senior Member
    Windows
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2017
    Jun 2007
    Seattle
    306
    [0,90],(270,0] - you can't use this as an entry because you are doubling up on 'zero'. That's why Libbya used 359.9999.
  7. #7
    Full Member
    Win 7
    HVAC
    AutoCAD 2016
    Jun 2015
    Slovakia
    37
    I meant [0,90],(270,) without last zero which mean greather tahn 270 based on AutoDask Help:
    (For an open-ended range, use one value with a comma, enclosed in brackets or parentheses. For example: [,5] specifies less than or equal to 5; (5,) specifies greater than 5.)
  8. #8
    Senior Member
    Windows
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2017
    Jun 2007
    Seattle
    306
    I didn't know that!
    Putting this here for future reference.
    https://knowledge.autodesk.com/suppo...5D72F-htm.html
    Thanks.
  1. Open a dynamic block in editor cause "Internalerror @8597"
    By MastroLube in forum AutoCAD Drawing Management & Output
    Last Post: 1st Dec 2016, 06:06 pm
  2. Update "Prompt" tab in an existing Block Attribute.
    By jlobo in forum AutoCAD General
    Last Post: 24th Mar 2014, 10:13 pm
  3. Missing "visible" block attribute
    By MikeMc52 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 29th Mar 2012, 09:48 pm
  4. Dynamic Block Effective Names & "Description" --> vla-get-Comments
    By rayg11757 in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Sep 2011, 01:06 pm
  5. Dynamic Block "Squeeze For Hole to Disappear"
    By DECHAL in forum AutoCAD Drawing Management & Output
    Last Post: 13th Jan 2009, 02:41 pm
