Results 1 to 7 of 7
    Forum Newbie
    Mechanical
    AutoCAD 2016
    Dec 2017
    4
    Default Autocad layer automation through external applicaiton - need guidances
    Hi,
    I have a requirement in layer management.
    There are many layers in a drawing.
    I need to give some layers as input through some application like excel or anything else.
    As a result the drawing should be opened with the input layers to be visible and remaining layer in off state or hidden.
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,020
    The easiest way is to open the dwg and set the layers a small delay. You can also set the open which dwg if required. There are a couple of different ways to set the layers use "layer states" or read a text file with the layer settings. You can modify a dwg before opening but that is a bit more difficult.
    If using excel it can write all the code required as a script file.
    Else more info is required and a lisp can be provided, there a lot of this type of request.
    need to know more about the layers in the dwg as an example
    -layer s 0 off * n on w*
    Senior Member
    Civil
    Aftertouch's Discipline Details
    Civil
    Engineer
    AutoCAD 2017
    Jul 2016
    Netherlands
    259
    You could use a ReadExcel function,
    Or a 'simple' list with the layers, and process that with a foreach function.
    Very simple example, no error catching or anytin'
    Code:
    (defun C:CADTUTUOR ( / )
    (setvar "CLAYER" "0")
    (setvar "Expert" 1)
    (command "-layer" "OFF" "*" "")
    (setq offlayerslist (list "Layer1" "Layer2"))
    (foreach x offlayerslist
    	(command "-layer" "ON" x "")
    Forum Newbie
    Mechanical
    AutoCAD 2016
    Dec 2017
    4
    Consider the drawing contains 30 layers.
    I need to open the drawing with a prompt that which are the layers should be shown?
    I will select 10 layers and others 20 will be hidden.
    Each time, I should not write a program or layers name.
    I need to select the layers through a checkbox or some other means.
    And these combinations will repeatedly change.
  5. #5
    Senior Member
    AutoCAD 2009
    Oct 2012
    317
    arunkumarunicorn
    Use this :
  6. #6
    Forum Newbie
    Mechanical
    AutoCAD 2016
    Dec 2017
    4
    Hi,
    I select the layers ( options & spec in excel ).
    Each spec is a layer in drawing.
    After selecting the layer from the excel,
    a process should initiate from excel to open the autocad drawing.
    The drawing should open with the checked layers from the excel as visible.
  7. #7
    Forum Newbie
    Mechanical
    AutoCAD 2016
    Dec 2017
    4
    Default Is it possible ?
    Hi,
  1. Autocad is unable to service automation request
    By Perifanos in forum .NET, ObjectARX & VBA
    Last Post: 16th Mar 2013, 10:09 pm
  2. Can we open AutoCAD LT 2005 and 2007 via OLE automation
    By sun in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th Oct 2008, 10:18 pm
  3. VB Automation - How to write text in superscript to AutoCAD ?
    By chill in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Apr 2008, 08:30 am
  4. select by layer automation
    By ChrisCMU in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Feb 2008, 07:57 pm
  5. AutoCAD + COM Automation
    By askrius in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Nov 2007, 01:40 am
Tags for this Thread
