Results 1 to 3 of 3
    Junior Member
    Mechanical 2016
    Oct 2015
    16
    Default Change block by changing attribute ?
    Is it possible to have attributes that change the block itself?
    For instance: I have blocks of different heights and widths
    example: a block with measurements 120x120
    Attribute Height: 120
    Attribute Width: 120
    If I were to change it to
    Attribute Width: 240
    Could the block be replaced by a block with measurements 120x240?
    Thanks in advance
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,118
    Nope, attributes can't drive blocks, but if you use dynamic blocks then altering either sizes or visibility states can change the values of the attributes.
    I've just been down graded from 2012LT to full Autocad 2017. I WANT LT BACK
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,160
    Maybe a way around if the block is 1x1 in size then you can make the block 120x140 using X & Y scale. But you would have to update attribute vals but also think about using a dim with everything turned off but distance.
  1. changing attribute text width without having to select the block...
    By chauncy274 in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Mar 2016, 08:27 pm
  2. Change block A inside block B using block B's attribute
    By Gotrekk in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Oct 2015, 11:01 pm
  3. Block attribute prompt change
    By Enigma in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Oct 2011, 08:10 am
  4. Change Block Attribute
    By forum32 in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Jan 2011, 10:03 pm
  5. Block Attribute answers ability to change block Physical Attributes??
    By Kaidoz in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Mar 2008, 10:25 pm
