How can I import the cut/fill values from excel into AutoCad 2016 dwg
Bruceybee
Hi forum,
I have got as far as obtaining cut/fill values in a column using excel, adjacent to their relevant point coordinates. Now I want to know how I can import the cut/fill value text from excel into AutoCad 2016 dwg, in their relevant positions.
The dwgs and xls files are available for reference, in the google drive using the link below. I want to import the cut/fill value in column F, as text in the as-built dwg.
Thanks,
Bruceybee,
Google drive link:
https://drive.google.com/open?id=1hG86NOYKA8JPazYSN5x_Kav-ARk5Ti9B
  • 3 months later...
Google Drive tells me that your file is in the trash bin. Could you re-upload it and probably make an example DWG drawing (with a few objects) of the result you're looking for?
Vittorio: The post you are responding to dates back three months. If the OP did not find a solution to his problem by now I doubt you'll see the example drawing anytime soon.
