Results 1 to 4 of 4
    Junior Member
    Mechanical 2016
    Oct 2015
    16
    Default Wall command, select inner wall-point
    When I'm working with the Architecture command "Wall"
    I can never select the outer side of the wall as a reference point.
    See the red dot, I'ld like to use this to draw the next wall from...
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,108
    Haven't you already posted this same question once? Double posting is not allowed.
    Are you using AutoCAD Architecture? Your profile shows Mechanical.
    Junior Member
    Mechanical 2016
    Oct 2015
    16
    Hi,
    Ow I couldn't find the older thread so I assumed something went wrong with publishing.
    I'm now testing Architecture, but the above thread-question is preventing me from working efficiently.
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,108
    I have moved your thread to the Architecture & ADT Forum, please ask your questions in the most relevant forum.
  1. I wnat to aplay the Photo as a wall paper to a round wall .
    By Gali in forum AutoCAD 3D Modelling & Rendering
    Last Post: 7th Nov 2016, 08:37 pm
  2. Wall Merge issue - Infill wall area for presentation purposes
    By tplight in forum Architecture & ADT
    Last Post: 20th Jun 2014, 04:24 pm
  3. Setting the srtart point of a Curtain wall
    By busseynova in forum Architecture & ADT
    Last Post: 19th Aug 2010, 09:54 am
  4. curtain wall tie to cavity wall
    By lorrayneprunty in forum Revit General
    Last Post: 23rd Mar 2010, 04:36 pm
