Leader sub menu modification
mjavy7
Hello All!
I would like to add another command to the pop up sub-menu (see attached image) that come up when you place your courser over a leader.
I would like ADD the option to remove a leader right in this sub-menu.
Is this possible?
Here is the command that I think I need to add to this menu.
^C^C_MLEADEREDIT _R
If this possible how do I get it done?
Thanks in advanced.
If you type CUI you get into the menu's you can add extra menu items into a menu use COPY & Paste (right click on menu item) then edit the copied item to your required command. I dont do things that way I have custom menus and throw away all the stuff I dont want. eg 1 menu = 3 menu's of commands 99% of the stuff I use very day.
Bigal, I need more help.
I went to the CUI and can not find the menu that I think I need.
I went to:
"ACAD" --> "Shortcut Menus" --> "MLeader Object Menu" and there is nothing in there like the picture above (1st post).
Am I in the correct place/menu?
A better explanation will be highly appreciated.
Thanks in advanced.
I knew you would come back, I really dont touch the Acad menu's but rather have custom ones so I would add what you want to a custom one. I just had a real quick look at it and it seemed possible as copy a command is an option in the CUI.
I may have time over weekend to look further which menu was it ?
I went to:
Thanks in advanced.
The "Shortcut Menu → MLeader Object Menu" is the one available when you right-click after selecting a MLeader Object.
You can add your command macro in there, but the one you have displayed above is displayed when hovering over a grip on a selected MLeader Object. Those menus cannot be modified in the CUI.
  • 3 weeks later...
Thanks tombu, I added it to the right-click menu and I can live with that :-).
