Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
  1. #11
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,759
    Quote Originally Posted by oftenly View Post
    Oh man, thanks for the responses guys, especially Dana! I actually got really angry with myself yesterday afternoon about this stuff, and kinda gave up on this thread, but I'm glad I decided to check it again!
    My afternoon's too tight to really try this stuff out, but I have some preliminary questions, if I may:
    - I understand assigning annotative scales... sorta. Setting ANNOAUTOSCALE to anything but 0, as Dana describes, is what I thought Autocad would already do naturally. It seems this basically gives you the option to assign a scale that is different from your viewport scale... and I don't know why anyone would ever want that. Maybe that's a dumb thing to say, since I've only been drafting for a year or so, but this entire concept just seems like a confusing middle-man to me. Is it not a foregone conclusion that I want the dimension line to be scaled to the viewport scale, whatever it may be? What else could I possibly want? I suppose these questions are more philosophical than technical...
    Letting AutoCad add the current scale automatically is for using the same set of dimensions in more than one viewport, of course. I however, prefer to add the second or third scale to particular dimensions manually. I guess if one had 400 viewports and only one model, like a nuclear sub or something to deal with, that would be another thing. Maybe then automatically adding the current scale would be a good thing. I still think there would be a nightmare of dimension spacing to look at and fix. There may be something I haven't learned yet about spacing out multi-scale annotative dimensions a uniform distance apart. It may be the fixed length extension line option, not sure. I intend to experiment with that as soon as some slack time hits at work. I don't draw nuclear subs, I draw cabinetry and millwork so I seldom need more than 40 or so viewports and three to four different scales.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  2. #12
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,759
    The beauty of putting all dimensions in one's layout......ONE dimension style and only ONE system variable to worry about....Associative.
    You apparently come from a planet where nothing that has already been dimensioned is ever modified.
  3. #13
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,759
    - "This is why I try very hard not to have more than one scale assigned to any one set of dimensions." -- This is exactly what I'm trying to do! I have dimensions in model space in a dynamic block, and I don't know the scale of the viewport in which they'll end up, but those model space dimension lines ultimately need to mimic my paper space dimensions. The viewport could be at literally any conceivable scale, and the block will be used across dozens if not hundreds of drawings. I don't think pre-assigning an infinite number of scales would really work...
    I am still working on this one too. I have found that everything stays 1:1 inside a block, so annotative scales are pretty much ineffective in there, at least for me, and any text stays the same relative size to the rest of the block. I am using one annotative block consisting of ONLY non-annotative multi-line text, so it scales to match individual viewports. I used to use it in paperspace non-annotatively but usually had to move it around for every new viewport.
  4. #14
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,759
    - Not sure if it's important, but my model space is always scaled at 1:1, as a rule.
    Not sure it's imp...... ...... people get fired or at least yelled at for not doing this. The worst two weeks of my life was spent modifying and correcting a huge project where the original draftsman had scaled every single view in modelspace simply to "fit nicely" at no particular scale in each of 344 separate full page viewports, all set to 1:1. I can now scale to a reference, in my sleep. Seriously, the drawing was a bunch of randomly scaled junk.
  5. #15
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,759
    Am I really the only guy who wants literally every dimension in every drawing to be the same format?
    Well, there's at least two of us.
    I don't like to toot horns in my own behalf, but out of the three draftspersons in my shop, I am the only one who has any written rave reviews of my drawings from our general contractors or project owners (clients), and I have six of them in the last two years. It is mostly due to me having close to 50 years drafting experience, but in that time I have learned the immeasurable value of uniform text and dimension formating.
    Making a drawing easily readable is at least 50% of drafting. The rest is not leaving anything out, and not including superfluous junk.
    There are people who feel it necessary to draw six separate views, and at least one section view of a featureless matte black solid cube of rubber and spend hours on google looking for the perfect rubber hatch for the section view.
    The secret is making sure the fabricators get everything they need to see without unnecessarily clouding things up with phouffy things the client thinks they need to see while not peeing off the client. It's kinda like keeping my wife happy.
  6. #16
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,759
    Quote Originally Posted by Dadgad View Post
    Late to the party and haven't read everything, but you mentioned scaling your model space at 1:1.
    One does not appy scale to modelspace but rather to viewports in your paperspace.
    Stick to drawing life-sized in your modelspace (1:1) and preferably in the appropriate (meaning intended) units, on an appropriate template, meaning either Metic or Imperial to suit your project.
    Dana, you really went the extra mile!
    Aw, shucks. Considering the level of complexity in scaling, and annotative scaling, it was only an extra inch.
  7. #17
    AutoCAD 2013
    Nov 2011
    6,031
    Quote Originally Posted by Dana W View Post
    That's what she said, about the complexity, meaning the former bartendress of your formative years!
    I still avoid annotative, and associative when using Autocad, for that matter, but using ProSteel, it is way beyond just Associative!
    Like ReMark, I am happiest dimensioning in Paperspace, and if I need to redimension something, so be it.
    In ProSteel, it is all done in Modelspace.
  8. #18
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,838
    They do but in our line of work 99% of the time the fact that the dimensions are associative makes it a non-issue.
  1. HELP to include "AcDbAlignedDimension" code for a "Dimension deleting" LISP
    By vernonlee in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Apr 2015, 04:03 pm
  2. Sheet Metal Cylinder - "Creating" & "Flatten" Question
    By vertical horizons in forum SolidWorks
    Last Post: 10th Jan 2014, 12:15 pm
  3. Export properties ("measurement") of "Aligned Dimension" to Excel
    By nhatquyelec in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Feb 2013, 07:58 am
  4. Dimension style "adds" number "1/8" as suffix
    By enemigoman in forum AutoCAD General
    Last Post: 26th Apr 2012, 04:15 pm
  5. Confused about "standard scale" and "custom scale" interaction.
    By tnb23 in forum AutoCAD Beginners' Area
    Last Post: 28th Jan 2009, 10:38 pm
