Results 1 to 9 of 9
    Junior Member
    Architectural
    AutoCAD 2014
    Sep 2017
    20
    Default Attribute to Object Field
    hi, can somebody help me?
    I want to select an attribute block and convert it to an Object Value field.
    Currently my workflow is this :
    Edit the attribute value
    Highlight and select "Insert Field"
    Under Field Category, I select Object
    Under object type I pick which object I want the field to insert
    Under Object Type properties, I select VALUE
    on the Preview, I choose Uppercase.
    wonder if this can be automated by just picking the attribute in the screen and convert it automatically to FIELD using Object Value.
    Thanks in advance.
    Luminous Being
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    9,901
    This is the reverse of what you want http://www.lee-mac.com/getfieldobjects.html but may give some ideas.
    Luminous Being
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    9,901
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,368
    You could use my Quick Field application to create a program which will allow you to accomplish this - please read the instructions provided on the program page and in the code header.
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  5. #5
    Junior Member
    Architectural
    AutoCAD 2014
    Sep 2017
    20
    I tried this one :
    Code:
    (defun c:test4 ( ) (LM:QuickField "Textstring" "%tc1" 1))
    and I get an error:
    Code:
    Command: TEST4
    Select Object with Textstring property:
    Object does not have Textstring property.
    I was selecting an Attribute tag that contains the value which I want to convert to field.
    This is the field expression :
    Code:
     %<\AcObjProp Object(%<\_ObjId 8796087809088>%).TextString \f "%tc1">%
  6. #6
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,368
    Oh, sorry you may need to change line 273 from:
    Code:
                    (list 'if '(setq ent (LM:quickfield:selectifhasprop prop entsel))
    to:
    Code:
                    (list 'if '(setq ent (LM:quickfield:selectifhasprop prop nentsel))
    The program will currently select the block reference when selecting an attribute within a block.
  7. #7
    Junior Member
    Architectural
    AutoCAD 2014
    Sep 2017
    20
    Hi Lee, it's turning the attribute into a Field but appears as ####.
    I've tried on several attribs and the result are the same. any thoughts why?
  8. #8
    Full Member
    not applicable
    May 2009
    84
    just regenerate the drawing (type "_rga" at the commandline)
    sysvar "fieldeval" may also be usefull
    regards
    Wolfgang
  9. #9
    Junior Member
    Architectural
    AutoCAD 2014
    Sep 2017
    20
    Quote Originally Posted by wkplan View Post
    regards
    Wolfgang
    I did re-generate but still the same. Fieldeval is set to 31.
  1. attribute with a field
    By samifox in forum AutoCAD General
    Last Post: 31st May 2016, 07:37 pm
  2. AutoLISP - move value from object data field to elevation field
    By cfculligan in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th Aug 2014, 08:12 am
  3. How to reference attribute in a field
    By krackpot in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 24th Jul 2009, 03:04 pm
  4. FIELD in Attribute
    By daveacad in forum AutoCAD Drawing Management & Output
    Last Post: 9th Mar 2009, 12:01 pm
  5. block with field attribute
    By tibi in forum AutoCAD Drawing Management & Output
    Last Post: 15th Nov 2008, 10:31 pm
