+ Reply to Thread
Results 1 to 3 of 3
  1. #1
    Forum Newbie
    Discipline
    Mechanical
    Using
    AutoCAD 2008
    Join Date
    Dec 2017
    Posts
    3
    Default Part list / Balloon question (AutoCAD 2008)
    Hello,
    This is my first post. Just want to say the forum has been a great source of help for me and I'm very grateful for it.
    Now on to my little question.
    I have a drawing which contains valves of different sizes. They are all blocks and each has an attribute that describes the type of valve and the size (something like this DN100 Ball Valve).
    I want to create a parts list (BoM) and display it as a table in the drawing. I managed to create the table with the "eattext" and it shows up nice. But what I don't know how or if it's even possible, is to add balloon numbering to every valve and then have the number show up in the table.
    So it would be something like this:
    1 - DN100 Ball Valve - 2 pcs
    2 - DN80 Ball Valve - 3 pcs
    where the number in front of each row is the actual balloon number.
    I used Inventor a lot and it was very easy to do this, but now I'm limited to AutoCAD and was wondering if I can still do it as it would really ease up the work process.
  2. #2
    Quantum Mechanic BIGAL's Avatar
    Using
    Civil 3D 2016
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    10,595
    Default
    So you want a valve number incrementing every time you add a valve, can it be part of the valve block makes life so much easier as its another attribute. You use a add a block compare to a list go find last number and add 1. www.lee-mac.com has a real nice number increment lisp.
  3. #3
    Forum Newbie
    Discipline
    Mechanical
    Using
    AutoCAD 2008
    Join Date
    Dec 2017
    Posts
    3
    Default
    But I would also like to link that valve number to the balloon. I'm not sure I explained it very good. Each valve has a balloon attached to it and inside there's the number of the valve. I'll link a picture and maybe that will clear things up a bit.
    http://www.cadalyst.com/files/cadaly...4/10253/i2.jpg
    So each part has a number, which then shows up as the Item number in the parts list table.
    Is that possible in AutoCAD 2008?
Similar Threads
  1. Part number Balloon numbering
    By cadmando2 in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 22nd Oct 2014, 03:40 am
  2. generate part-list/order-list in autocad 2011LT
    By Borken in forum AutoCAD Beginners' Area
    Last Post: 12th Jul 2012, 09:39 am
  3. part in assembly, cannot balloon in drawing
    By linnmaster in forum Autodesk Inventor
    Last Post: 12th Mar 2010, 05:18 pm
  4. AutoCAD Mechanical 2008 - Balloon Re-Scale?
    By Ste1978 in forum Mechanical & MDT
    Last Post: 24th Mar 2009, 05:03 pm
  5. Yet another Balloon question
    By mcguirepm in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Oct 2008, 09:32 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
