SSGET for blocks question
ziele_o2k
I whant to select dynamic blocks with some conditions:
  1. Each block scale has to be grather than 0
  2. X Y and Z scale factor has to be the same for indivdual block
I know how to get blocks with condition No.1 inside ssget, but can it be done for second one?
Example:
  • Block 1: scale factors X=1 Y=1 Z=1 (select)
  • Block 2: scale factors X=-1 Y=-1 Z=-1 (don' t select)
  • Block 2: scale factors X=2 Y=3 Z=2 (don' t select)
  • Block 3: scale factors X=4 Y=4 Z=4 (select)
To get blocks with scale grather than 0 I can use:
(ssget
 (list
   (cons 0 "INSERT")
   (cons 410 "Model")
   ;(cons 2 Anonymous References of dynamic block)
   (cons -4 "<AND")
     (cons -4 ">") (cons 41 0)
     (cons -4 ">") (cons 42 0)
     (cons -4 ">") (cons 43 0)
   (cons -4 "AND>")
Can I add condition to function above which will check if 41 42 and 43 codes are equal?
Workaround solution can be this one:
Workaround solution deleted
Edited by ziele_o2k
Workaround solution was wrong.
Personaly i would use your 'workaround' to filter the selection, since the SSGET can get very confusing.
Also, i double it can handle a '=' check for multiple AND variable values...
In your workaround you finally filter inserts based on their name and layout. The result can include inserts with faulty scaling factors.
True, my workaround is wrong, I can write another (in my case it would be great if ssget would work with ename or handle :) ).
Nevertheless this is not my question :)
