Results 1 to 9 of 9
    Forum Newbie
    AutoCAD 2015
    Nov 2014
    4
    Default autocad degree numbers help
    Hello.I hawe one problem.I use autocad occasionalli an im amateur in this program and now i hawe one problem.A made degree wheel and now i dont know how to insert degree number like on pictures.Could someone help me to solv this problem.
    Thanks
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,623
    One way would be to correctly position (use bottom center for justification then rotate to correct starting angle) a representative number (ex. - 1) at the start of the degree wheel then create a polar array. You know the number of items and the angle the array must fill. Once the numbers (they will all be the same of course) are inserted explode the array and then change each number in sequence. Crude, I grant you, but it would work.
    Here is an example.
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,076
    I used Remark's array method, but then went on with Express Tool's Automatic Text Numbering, and then Find to attach the degrees sign. Perhaps a step too far!
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,623
    Even easier.
  5. #5
    Forum Newbie
    AutoCAD 2015
    Nov 2014
    4
    This is not gut.Numbers are to close to lines.I need exactly like on picture.
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,623
    Quote Originally Posted by rado7rado View Post
    Both methods work just fine. It is up to the user to determine the spacing between the end of the line and the number. If you don't know how to make that happen you should probably enroll in a basic AutoCAD class.
  7. #7
    Forum Newbie
    AutoCAD 2015
    Nov 2014
    4
    I just ask for help not for prich.If you are willing to help then help if not please live my thread.
  8. #8
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,076
    I was merely showing a method to do things. The details are up to you. That is why a picture is shown rather than a drawing, and the numbers are shown at that size and spacing for better visibility in the posted picture.
    You know now that what you want is capable of being done, and how to do it.
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,623
    All text related commands in AutoCAD allow the user to specify the starting position of their text as well as the justification. Temporary geometry, polar tracking and other features of AutoCAD can be used to more accurately aid in text placement. Bottom line: there are options. You just have to explore those options and pick the one that works best for your given situation.
  1. Need Help creating a tube with a 45 degree angle in autocad
    By karolbyrne in forum AutoCAD General
    Last Post: 7th Jan 2012, 02:48 am
  2. 0 degree is vertical as 90 degree
    By symoin in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 19th Jul 2011, 12:37 pm
  3. Convert integers numbers into real numbers, introducing decimal separator.
    By teknomatika in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Sep 2010, 04:07 pm
  4. do i need a degree in ... to do autocad ???
    By FunkyCatSpangky in forum AutoCAD Drawing Management & Output
    Last Post: 31st Aug 2006, 01:00 am
