ReMark Posted December 12, 2017 Share Posted December 12, 2017 Every now and then AutoCAD 2018 will create a file with the extension .idw! Does anyone else here, who uses 2018, experience the same quirk? The drawing referenced below is a 3D drawing of a tank farm that I am currently working on. Quote Link to comment Share on other sites More sharing options...
rlx Posted December 12, 2017 Share Posted December 12, 2017 seems to be an (inventor) image file http://whatis.techtarget.com/fileformat/IDW-Autodesk-Inventor-schematic-drawing-file Quote Link to comment Share on other sites More sharing options...
steven-g Posted December 12, 2017 Share Posted December 12, 2017 I've had 2018 for a couple of weeks now, and no I haven't seen it do that. Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 12, 2017 Author Share Posted December 12, 2017 I pretty much knew what it was. What I don't know is the "why" of it. Cannot recall this happening in AutoCAD 2017 despite having created many 3D drawings in the program. Then along comes 2018 and SURPRISE! Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 12, 2017 Author Share Posted December 12, 2017 I've had 2018 for a couple of weeks now, and no I haven't seen it do that. Have you created any 3D drawings? I just discovered that the .idw file is created when I open my 3D drawing and it disappears after I close the drawing. Odd. Quote Link to comment Share on other sites More sharing options...
steven-g Posted December 12, 2017 Share Posted December 12, 2017 Basic stuff, extruded solids, nothing fancy, in my field it's all walls and floors. Quote Link to comment Share on other sites More sharing options...
rlx Posted December 12, 2017 Share Posted December 12, 2017 I rarely use 3d but problem seems to be a bug https://forums.autodesk.com/t5/autocad-mechanical-forum/acad-saves-idw-files/td-p/5675860 hope you find a (bug) fix or someone who knows how to switch this option off gr. Rlx Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 12, 2017 Author Share Posted December 12, 2017 I do have DWG TrueView installed. I did not use the VIEWBASE command in the creation of the drawing although I did use FLATSHOT. One thing does occur to me. I imported two 3D IGES files (a valve and a bushing) from the McMaster-Carr website. Perhaps that has something to do with it. I will have to test that assumption. Quote Link to comment Share on other sites More sharing options...
