Results 1 to 6 of 6
    Full Member
    AutoCAD 2005
    Feb 2011
    35
    Angry Need quick help.. HELP HELP HELP
    This may be a simple fix, but I'm stuck. When I went to open an Autocad 2006 drawing this morning, an Autocad box came up on the bottom of my screen and the drawing did not open. When I hover my cursor over the Autocad box at the bottom of the screen, the drawing opens just above the box, but it is like 1"x2" in size. The drawing is all there, but small. I can't figure out how to get the drawing to open full screen. It may be a click of a button, but I'm not sure which button.
    Please help ASAP as I need to work on my drawings. This is the first time this has ever happened. I restarted my computer twice but still does the same thing. HELP !!
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    It sounds as though you minimized AutoCAD at some point which is just like minimizing any other Windows program. Did you try stretching the box using your mouse?
    Full Member
    AutoCAD 2005
    Feb 2011
    35
    No, it won't stretch at all..
    Senior Member
    AutoCAD 2009
    Oct 2012
    340
    attach screen image
    Software development
    Batch printing drawings from model and printing PDF to different printers
    https://www.kdmsoft.net
  5. #5
    Full Member
    AutoCAD 2005
    Feb 2011
    35
    Default I fixed it..
    I use a 2nd monitor on occasion, but I typically have it turned off. So for what ever reason, the drawing went to the 2nd monitor which I had turned off. I turned on the 2nd monitor and there is my drawing full size. What a dummy I am...
    I just never use that 2nd monitor that much and for whatever reason, the drawing went to the second monitor.. So I just dragged the drawing back to my main monitor. Problem solved after 2 hours wasted.. Oh well.
    Thanks guys for you time..
  6. #6
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,214
    Thank you for posting the resolution to your issue.
    breaking AutoCAD on a regular basis since 1991
  1. New Thread Suggestion: Quick Question, Quick Answer
    By Pintoleite in forum Feedback
    Last Post: 11th Apr 2012, 01:23 pm
  2. Quick Select/Quick Filter
    By mike06 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 29th Mar 2008, 01:33 am
  3. Is there a quick way of
    By Norts in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Feb 2007, 06:57 pm
  4. A Quick Tip on Quick Leader
    By CAD-e-Corner in forum AutoCAD RSS Feeds
    Last Post: 21st Nov 2006, 10:51 pm
  5. Hopefully just a quick one...
    By FindAPath in forum AutoCAD 3D Modelling & Rendering
    Last Post: 21st Apr 2006, 07:43 pm
