Results 1 to 4 of 4
    Junior Member
    AutoCAD 2011
    Nov 2006
    21
    Default Lineweight when publishing as TIFF file
    AutoCAD 2016
    Right now we pdf (and it looks great), then we saveas a TIFF file. PDF lineweights look good, and so do the new TIFF lineweights.
    We are trying to publish straight to a TIFF file, but are lineweights are to fine.
    I've tried going into the imported "page setup" file and changing the lineweight in the page setup manager's "plot style table", but that did nothing.
    Any suggestions?
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,402
    We publish to TIFF direct basicly had to redo the CTB table with thicker lines, as tiff's are controlled by the DPI so line thickness' tends to go thin.
    Junior Member
    AutoCAD 2011
    Nov 2006
    21
    Thanks. This gave me some place to start. Got it to work in plot, but I'm still working on how to accomplish this when publishing. Doesn't seem to be taking the CTB from the imported file. Any hints?
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,402
    I dont use publish rather a lisp and plot. You may need to set up the 1st sheet with correct parameters save its setting say as "TIFF" (plot screen top left) then in publish copy this setting to all sheets.
  1. Tiff file becomes transperent when rotated!
    By Dacx in forum AutoCAD LT
    Last Post: 1st Apr 2015, 06:27 pm
  2. Importing a tiff file
    By Willis in forum AutoCAD Beginners' Area
    Last Post: 30th Oct 2008, 10:03 pm
  3. Inserting TIFF File
    By Hoover in forum AutoCAD Beginners' Area
    Last Post: 3rd Oct 2008, 05:04 pm
  4. Publishing to TIFF...
    By tzframpton in forum AutoCAD Drawing Management & Output
    Last Post: 4th Oct 2006, 10:37 pm
  5. Import and trace a tiff file into a cad dwg.
    By LAWBC in forum AutoCAD General
    Last Post: 4th Mar 2004, 04:06 am
Tags for this Thread
