Results 1 to 5 of 5
    Senior Member
    OMEGA-ThundeR's Computer Details
    Windows 10
    HP Z440
    Civil
    OMEGA-ThundeR's Discipline Details
    Civil Engineer (CAD Design)
    Civil
    AutoCAD 2017
    Oct 2008
    Netherlands
    321
    Default Viewport shows annotationscale selector
    Hi,
    I'm setting up a new template and setting up different layouts with different papersizes and such.
    When i create a viewport is shows a center grip and a selectionarrow much like an visibility. When i press it it will show my all the annotation scales (scalelistedit command).
    i'm not used to this and we don't use annotation scales.
    How do i make my viewports normal again?
    I'm using Civil3d 2018 as Autocad (the C3D shortcut way, so not in a figure of speech), so that probably is my mistake in the first place
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    I don't see the center grip, or the pop-up list arrow at all in 2018 LT. There must be a sysvar for changing that. One I am not aware of. But, not to worry. That scale list is your viewport display scale list, (Standard Scale in Properties) not the annotative scale.
    Here is an operating instruction copied from AutoCad Help just now...
    To change the display scale, click the triangular scale grip near the center of the layout viewport. You can also select the edge of the viewport object, and specify the viewport scale in the Properties palette.
    I may try to figure out why I don't see that scale list grip in my new viewports. I've never known about it.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
    Senior Member
    Civil
    Aftertouch's Discipline Details
    Civil
    Engineer
    AutoCAD 2017
    Jul 2016
    Netherlands
    304
    Yes, i noticed it too,
    but im actualy happy with it, since we use annotationscales every day on every project. :-)
    But i cannot seem to find any documentation of a variable to turn it off.
    Senior Member
    Windows 10
    HP Z440
    Civil
    Civil
    AutoCAD 2017
    Oct 2008
    Netherlands
    321
    I believe it must be some systemvariable too, it was just there (like most weird stuff that happens in AutoCAD like the 'random' pickfirst or filedia command changes), i didn't notice it the first weeks of use ..
    But it's 'strange', and since the template will be used by others i don't want any spotted necks on my co-workers for changes they don't use or understand .
  5. #5
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    I wonder if it has something to do with whether one displays the Annotation Scale button on the task bar. I do use the button on the taskbar, and the list you see does not show when I insert a new viewport.
  1. Viewport issue-Nothing shows up in it
    By farfalu in forum AutoCAD Beginners' Area
    Last Post: 30th Apr 2015, 10:43 am
  2. Hatch doesn't appear when applying it from viewport but shows fine on model space.
    By mgmarisa in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 31st Mar 2015, 05:49 pm
  3. Layer turned on but does not show in model space, shows in one viewport & not another
    By crosscad in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 28th Sep 2011, 12:45 am
  4. Block selector
    By sakinen in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Jun 2010, 08:13 pm
