Results 1 to 1 of 1
    Senior Member
    AutoCAD 2015
    Jan 2015
    151
    Default Dimension points go far away from text
    Hi there!
    I'm not sure how to explain that but I copied a lot of quotes from another file and I get their defpoints so far away from the quotes!
    Now I've learned a command "_DIMDISASSOCIATE" that is very useful when you copy or move something but how can I fix that problem?
    Please have a look at this example file for a better understanding.
    Thanks!
    Dennisquote problem.dwg
  1. Change dimension line length when text is outside / beside dimension
    By mane222 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 29th Jun 2016, 03:36 pm
  2. Picking Dimension Points
    By gbradley in forum Autodesk Inventor
    Last Post: 6th Jan 2016, 02:52 am
  3. HELP: Dimension text will change to a wrong measurment when dimension text is moved
    By vernonlee in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 9th Feb 2015, 01:59 am
  4. Dimension of A polyline by clicking on 2 points?
    By danielk in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Aug 2013, 09:35 am
  5. How to get Dimension points in VBA?
    By gerain04 in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Mar 2010, 10:18 am
