Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Junior Member
    AutoCAD 2017
    Oct 2017
    19
    Question Creating a curve with radius 5 circles
    If drawing two radius 5 curves, so that the horizontal is 8 units as shown, where would you place the centres of the 5 radius circles?
    I think possibly also a circle may have to be offset to achieve this, I'm not sure.
    I've tried various scenarios of radius 5 circles, but can't get it to quite match.
    Thanks for any help!
    Junior Member
    AutoCAD 2017
    Oct 2017
    19
    I'm fairly sure I've now sorted this.
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,146
    To get all circles to be tangential, there is only one solution to your problem, given the required circle radius, and it determines what is the vertical dimension between the lines.
    As you have solved it, perhaps you could share your method for the benefit of others.
    Junior Member
    AutoCAD 2017
    Oct 2017
    19
    The way I went about it was as follows.
    I drew a radius 10 circle centred on the right side of the measurement 8.
    Then I drew a radius 5 circle centred on the left side of the measurement 8.
    Then where this last circle and the radius 10 circle intersect I drew a new circle of radius 5 (highlighted in image below.
    Then I trimmed away excess.
  5. #5
    Junior Member
    AutoCAD 2017
    Oct 2017
    19
    Also, I started off with a radius 5 circle centred on the right of the measurement 8. Should have mentioned that.
  6. #6
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,146
    Thank you for sharing your solution.
    It is pretty much how I drew it up, but, as ever, there are many ways that lead to the same solution, although some use fewer key strokes than others!
  7. #7
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    825
    Too much information. For the arcs to be tangent to lines and each other you cannot hold both the 5' radius and the horizontal distance of 8'. The image above holds only the 5' radius.
    Layer 0 for ByBlock Block entities, everything else ByLayer. So many issues can be solved with good templates.
  8. #8
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,146
    I would have thought just enough information. For a horizontal distance of 8, there are arcs of many radii to join, but each arc has its vertical distance.
  9. #9
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,165
    The question implies that the distance of 8 units is the distance between the centres of the two arcs measured horizontally, it also implies that the where the arcs meet they are tangent. With only that information there are 2 answers.Both of which use a vertical difference of 6 units between the centres. Though obviously, only one meets the visual image given.
    I've just been down graded from 2012LT to full Autocad 2017. I WANT LT BACK
  10. #10
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,146
    Quote Originally Posted by steven-g View Post
    The question implies that the distance of 8 units is the distance between the centres of the two arcs measured horizontally, it also implies that the where the arcs meet they are tangent..........
    There are in fact a couple more answers (what is a negative sign between friends), but scenario 1 seems to meets the OP's requirement.
  1. Hello! I need to curve 3D object on radius, if possible hellp pleas. Thanks.
    By S1L3NC3 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 3rd Feb 2017, 01:17 pm
  2. Routine to Select Circles by Radius or Diameter
    By troggarf in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Sep 2013, 01:58 am
  3. ObjectARX - Selected Circles Center and radius.
    By gnanapaul in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Dec 2009, 11:02 am
  4. AutoLisp for selecting Similar Radius Circles
    By sparami in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd May 2009, 12:46 pm
  5. circles on a radius
    By autocack in forum AutoCAD Beginners' Area
    Last Post: 10th Feb 2009, 03:13 pm
