Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
  1. #11
    Junior Member
    AutoCAD 2017
    Oct 2017
    19
    I was having a look again at the replies by eldon and steven-g above.
    From my attempt, shown in the 2nd image I posted above, the vertical height of the curve I drew would be 5 since the circles were radius 5.
    Are you both saying that the vertical height should be 4?
    How do I position the radius 5 circles to achieve the height of 4? Or do I use one of the tan functions within AutoCad to achieve this?
  2. #12
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,103
    The initial requirement was for a reverse curve using curves of radius 5, with a horizontal separation of the tangent points being 8. There is only one solution for this and the vertical separation of the tangent points just happens to be 4.
    To construct this, I first of all drew the line A. Offset this upwards by 5, and draw line B to join the end at C. Draw a circle radius 5 centred on C, and offset this outwards by 5 to give circle D. Offset the line B by 8 to the right, and extend it downwards to meet circle D at E. This is the centre of your second 5 radius circle. Measure up 5 from E to give the second horizontal line. This happens to be 4 higher than the first horizontal line. Draw in the circles and horizontal line, trim and there you are.
    However, I noticed that the difference in coordinates were nice small integers, and using the fact that AutoCAD will draw an arc tangential to a line or arc drawn immediately before, I drew the lines and reverse curve directly with this as the command line:-
    LINE Specify first point:
    Specify next point or [Undo]:
    Command: a
    ARC Specify start point of arc or [Center]:
    Specify end point of arc: @4,2
    Command: a
    Command: l
    Length of line:
  3. #13
    Junior Member
    AutoCAD 2017
    Oct 2017
    19
    Thanks very much for that. I tried that for myself using your first method.
    Interesting that it does give a different solution to my original attempt.
  4. #14
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,135
    Here is the mathmatical answer
    r1=r2 = (H^2 + dist^2)/4H
    0=H^2-r*H+dist^2 solve for H
    If r=5 H=4
  1. Hello! I need to curve 3D object on radius, if possible hellp pleas. Thanks.
    By S1L3NC3 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 3rd Feb 2017, 01:17 pm
  2. Routine to Select Circles by Radius or Diameter
    By troggarf in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Sep 2013, 01:58 am
  3. ObjectARX - Selected Circles Center and radius.
    By gnanapaul in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Dec 2009, 11:02 am
  4. AutoLisp for selecting Similar Radius Circles
    By sparami in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd May 2009, 12:46 pm
  5. circles on a radius
    By autocack in forum AutoCAD Beginners' Area
    Last Post: 10th Feb 2009, 03:13 pm
