+ Reply to Thread
Results 1 to 8 of 8
  1. #1
    Full Member
    Using
    AutoCAD LT 2014
    Join Date
    May 2011
    Posts
    95
    Default Need help with understanding annotations
    Is there a video guide or tutorial on understanding annotations?
    I want all my text in model space to be a height of 40 but in layouts, i need them to be 5 regardless of scale in the view ports.
    Is this possible? I always had trouble getting it right for some reason.
  2. #2
    Luminous Being RobDraw's Avatar
    Using
    MEP 2017
    Join Date
    Apr 2007
    Location
    Connecticut, USA
    Posts
    5,173
    Default
    Lots of them.
    Search for Annotative Scaling.
    Drafting is a breeze.
  3. #3
    Super Member
    Computer Details
    Ski_Me's Computer Details
    Computer:
    DELL (why oh lord must I suffer)
    Discipline
    Electrical
    Ski_Me's Discipline Details
    Occupation
    Fire Alarm tech
    Discipline
    Electrical
    Using
    AutoCAD 2018
    Join Date
    Apr 2012
    Location
    Edmond. OK
    Posts
    638
    Default
    neuri I have been trying to answer your question for days but my computer keeps kicking me out. Ok so you stated you want a annotative ratio of 5:40 which is the same as 1:8 since 8*5=40. Now I know you said you want your paperspace text to be 5 no matter what the viewport scale but you have to think in terms of the size paper your going to output on. If your paper is big the text size will be to small, if your paper is small then your text size will be to big. So what you want is the ratio of your text in paperspace and modelspace to be the same no matter what the viewport scale is in paperspace. The easiest way to do this is to make sure that your annotative scale is always set to 1:8. The attached drawing has 2 layouts, one is 1:8 scale and the other is 1:16 in both cases the annotative scale is 1:8. Simply click on the viewport go to properties and you can see the viewport and the annotative scale. From here you can adjust the annotative scale.
  4. #4
    Using
    MEP 2017
    Join Date
    Apr 2007
    Location
    Connecticut, USA
    Posts
    5,173
    Default
    Quote Originally Posted by Ski_Me View Post
    Drafting 101 says this is wrong. The OP has it right. The text size should be the same no matter the size of the paper, in this case 5.
  5. #5
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2018
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    46,837
    Default
    Avoid the confusion and put all your text and dimensions in your layout instead of in model space. Just make sure dimensions are associative which is not the same as annotative.
  6. #6
    Full Member Incognito Cube's Avatar
    Computer Details
    Incognito Cube's Computer Details
    Operating System:
    Windows 10 Pro
    Computer:
    Dell Precision T1700
    CPU:
    Intel(R) Xeon(R) CPU E3-1225 v3 @ 3.20GHz
    RAM:
    8Gb DDR3
    Graphics:
    #1: Intel(R) HD Graphics P4600/P4700 #2: NVIDIA Quadro K620
    Primary Storage:
    WDC WD5000AAKX-75U6A SCSI
    Monitor:
    x2 Dell E2011H
    Discipline
    Surveying
    Incognito Cube's Discipline Details
    Occupation
    Platting Technician
    Discipline
    Surveying
    Details
    ALTA Surveys, Mortgage Surveys (Plot Plans, Finals, etc.), Plats, Boundary/TOPOs.
    Using
    Civil 3D 2014
    Join Date
    Jan 2018
    Location
    Orlando, Florida
    Posts
    38
    Default
    Quote Originally Posted by ReMark View Post
    Hi ReMark, in the interest of educating myself, what is the advantage of this besides being able to have absolute control on the text size? Wouldn't this only be beneficial to drawings with one sheet or maybe for details?
    As a young drafter always looking to better my practice, I'm always looking to learn from those more experienced than myself. The surveying co. I work for has always told me that text and dimensions are for model space only (mainly due to the fact that our projects tend to be composed of multiple sheets) to keep things organized and clean.
    Respectfully,
    - IC
  7. #7
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2018
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    46,837
    Default
    While the suggested method works for some, like myself, it would not be practical for others. That's why I usually state it depends on what field the person works in. I also recommend testing both methods then pick the one that works best for your situation.
    I've done multi-sheet projects using the method I describe with no problems to speak of. Most of those were piping fabrication details. Since it appears that you operate in the civil world annotative scaling would probably be the preferred method.
  8. #8
    Computer Details
    Operating System:
    Windows 10 Pro
    Computer:
    CPU:
    RAM:
    8Gb DDR3
    Graphics:
    Primary Storage:
    Monitor:
    x2 Dell E2011H
    Discipline
    Surveying
    Occupation
    Platting Technician
    Discipline
    Surveying
    Details
    Using
    Civil 3D 2014
    Join Date
    Jan 2018
    Location
    Orlando, Florida
    Posts
    38
    Default
    Makes sense. Thank you for the insight!
Similar Threads
  1. Annotations or Leader lines?
    By hands in forum MEP
    Last Post: 1st May 2015, 09:15 pm
  2. Annotations won't plot
    By julimor in forum AutoCAD Drawing Management & Output
    Last Post: 8th Apr 2014, 04:55 pm
  3. annotations
    By smaphosa in forum AutoCAD Drawing Management & Output
    Last Post: 10th Oct 2013, 11:27 am
  4. Reversed Annotations
    By T250AP4 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 8th Aug 2013, 12:35 pm
  5. no annotations in PDF output
    By Yagoona in forum AutoCAD Drawing Management & Output
    Last Post: 24th Oct 2011, 01:48 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
