Results 1 to 6 of 6
    Forum Newbie
    Simmy030's Computer Details
    Windows 10
    See details...
    Simmy030's Discipline Details
    Retired
    See details below.
    Health professional
    AutoCAD 2017
    Dec 2017
    UK
    2
    Default Problem drawing a wooden cart wheel
    Although I have used Autocad. 2d for a few years I am new to 3D.
    I am trying to draw the cart wheel shown in the color photo but I cannot draw the spoke properly. I have attached a drawing of the spoke with cross sections. As you can see the lower part is tear drop shaped but the upper half is rectangular. I have used the LOFT command to draw the lower teardrop shape with no problem but as you can see from the screen shots of realistic and wireframe views of the top transition from teardrop to rectangular, I hope, the left half of the upper end is OK but the right half does not match.
    Any help will be greatly appreciated.
    AutoCAD 2013
    Nov 2011
    5,985
    Welcome to CADTutor Simmy030.
    A more accurate description, would be to say that you are having difficulty MODELING the cart wheel, as a drawing is typically a 2D representation of a 3D object.
    I am not at my cad computer at the moment, but I would suggest using the SLICE command to create the flattened face at the transition.
    There is a wealth of video tutorials online, and some good lessons on the Tutorials tab, here on the forum.
    Give SLICE a try, read the commandline prompts, the better to understand the numerous available options.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,623
    Did you try reversing the selection of the lofted profiles? I suspect you first picked the teardrop profile followed by picking the more rectangular profile. Reverse the two picks and see what happens.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,881
    I have moved your thread to the AutoCAD 3D Modelling & Rendering Forum.
  5. #5
    Forum Newbie
    Windows 10
    See details...
    Retired
    See details below.
    Health professional
    AutoCAD 2017
    Dec 2017
    UK
    2
    Thank you for your help. Attached is a screen shot of my progress so far. The hub is still to be refined.
    As one half of the upper part of the spoke was OK I used the SLICE tool to cut it in half, discarded the unwanted half then mirrored and UNIONED the remaining part.
  6. #6
    Senior Member lrm's Avatar
    lrm's Computer Details
    Windows 7 64-bit
    16 GB
    Education
    lrm's Discipline Details
    Teacher, AEC and mechanical
    Education
    Civil and Mechanical
    3ds Max 2017
    Jan 2010
    Massachusetts, USA
    357
    MOdeling this was more challenging than I thought it would be. I thought the problem was that the top profile started in a corner and the if it started midway lofting would give a better result. It did not.
    I therefore decided to clip off some of the teardrop as can be seen in the sequence of images below. Using loft I created a surface from the truncated teardrop to the full top shape. I then used SURFSCULPT to turn it into a solid. I then created a network surface from the line at the top to the spline at the bottom, mirrored it and then added a couple of planes to define a watertight volume that was used by SURFSCULPT to create a solid. Finally, a Boolean union was used to combine the 2 solids.
  1. Problem with Mouse Scroll Wheel
    By valeriek29 in forum AutoCAD Drawing Management & Output
    Last Post: 18th Dec 2012, 09:55 am
  2. Drawing a Car Wheel in AutoCAD (HELP)
    By Bobzy20 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 23rd Jun 2010, 09:26 pm
  3. Zoom Wheel problem with 2009
    By PatFES in forum AutoCAD Drawing Management & Output
    Last Post: 26th Mar 2009, 09:47 pm
