Results 1 to 6 of 6
    Junior Member ehsantavassolian's Avatar
    Surveying
    ehsantavassolian's Discipline Details
    Civil Engineer
    Surveying
    AutoCAD 2012
    Oct 2017
    Iran tehran
    14
    Unhappy How can I translate \ to \\
    i want to translate \ to \\
    For Example translate
    "\\Pc1\source"
    to
    "\\\\Pc1\\source"
    I wrote this
    (vl-string-translate "\" "\\" "\\Pc1\source")
    But there is a problem
    The system does not accept "\"
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,590
    A single backslash in AutoLISP is an Escape Character, used to give an alternative meaning to characters which follow it (e.g. "\t" is the tab character). Therefore, before you pass the input string to an AutoLISP expression, you will first need to correctly represent the backslashes as literal backslashes within the string:
    Code:
    _$ (setq str "\\\\Pc1\\source")
    "\\\\Pc1\\source"
    Note that this will be printed with half the number of backslashes:
    Code:
    _$ (progn (princ str)(princ))
    \\Pc1\source
    Now, if you really wish to double the number of backslashes in the output string, there are a number of ways to accomplish this - here is one way:
    Code:
    _$ (vl-string-trim "\"" (vl-prin1-to-string str))
    "\\\\\\\\Pc1\\\\source"
    This output string will then be printed:
    Code:
    _$ (progn (princ (vl-string-trim "\"" (vl-prin1-to-string str)))(princ))
    \\\\Pc1\\source
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    Senior Member
    Stefan BMR's Computer Details
    Win10
    Structural
    AutoCAD 2019
    Sep 2011
    Baia Mare, Romania
    392
    The string "\s" is 1 char length. You can check it.
    Code:
    (strlen "\s") -> 1
    (substr "\s" 1) -> "s"
    It is impossible to even set a variable to your source string.
    So first thing is to check your variable. Try both (princ my_var) and (prin1 my_var), the real content of the variable is what the prin1 returns.
    Surveying
    Civil Engineer
    Surveying
    AutoCAD 2012
    Oct 2017
    Iran tehran
    14
    Unhappy Thanks for your description
    I learned your training
    I tried a lot . But it's not working properly on this example
    \\Pc1\source
    Intended character is deleted
    \\\\Pc1source
  5. #5
    Super Member rlx's Avatar
    rlx's Computer Details
    W10
    i74ghz/ssd500/2tbhdd
    Electrical
    rlx's Discipline Details
    electrical designer dragon
    Electrical
    I dont excel in anything but I rearly give up
    AutoCAD 2016
    Nov 2014
    Bergen op Zoom , Netherlands
    1,057
    Quote Originally Posted by ehsantavassolian View Post
    \\Pc1\source
    \\\\Pc1source
    There are only 2 ways you can enter this string :
    Code:
     (setq path "\\\\Pc1\\source")
    or
    Code:
     (setq path "//Pc1/source")
    even if your path is read from a (text)file lisp would automaticly translate "\\Pc1\source" to "\\\\Pc1\\source" so if you yourself enter this path manually you must use this string as shown above in your lisp code. If you let a user enter the path through a getstring you would get something like this :
    Command: (setq path (getstring "\nPath : "))
    Path : \\pc1\source <- you type one double and one single backslash
    "\\\\pc1\\source" <- lisp automaticly translates this to four and two backslashes
    gr. Rlx
  6. #6
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,590
    \\Pc1\source
    \\\\Pc1source
    The backslash character is not 'deleted' as it was never there in the first place - per my post above, a single backslash in AutoLISP is an Escape Character. If you want to represent a backslash in an AutoLISP string, you need to prefix it with another backslash to mark it as a literal backslash and not an Escape Character.
    Please re-read my post above.
  1. Translate english to ?
    By wastewater in forum AutoCAD General
    Last Post: 15th Feb 2016, 10:12 am
  2. vl-string-translate
    By Happy Hobbit in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Nov 2015, 06:54 am
  3. vl-string-translate
    By muthu123 in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Jul 2010, 08:02 pm
  4. translate please
    By guitarguy1685 in forum AutoLISP, Visual LISP & DCL
    Last Post: 4th Dec 2009, 09:35 am
  5. Translate point to current UCS
    By chavlji in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Feb 2009, 12:31 am
