Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 45 of 45
  1. #41
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,118
    Basic geometry, the ellipse major and minor would be 0.7071 of the distance between the diagonals of the isometric (square). So copy the rhombus using its own center and scale one of them from the center by a factor of 0.7071 and then use the points of that to draw your ellipse.
    I've just been down graded from 2012LT to full Autocad 2017. I WANT LT BACK
  2. #42
    Senior Member
    AutoCAD 2014
    May 2014
    153
    Quote Originally Posted by BIGAL View Post
    Maybe one way ellipse Centre M2P pick the end points for the centre of ellipse then use Perp to pick the edge.
    What is M2P?
  3. #43
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,118
    It's a "command modifier" when a command is active and is expecting you to select a point with the mouse, you can type m2p or mtp, and Autocad will then let you pick 2 points and it will work out a position halfway between those 2 points 'm2p' mid 2 points or midway between two points. It's worth looking in the help file for other command modifiers.
  4. #44
    Senior Member
    AutoCAD 2014
    May 2014
    153
    It seem few people here know about projection.
  5. #45
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,118
    I don't know about the others but I'm old school (well old anyway), I learnt on the drawing board and you had to know how to construct certain types of geometry.
  1. Cover from technical drawing
    By 10hi-f9s in forum SolidWorks
    Last Post: 14th May 2015, 05:06 am
  2. What makes a great Technical drawing?
    By Pablo Ferral in forum CAD Management
    Last Post: 9th Aug 2012, 10:47 am
  3. Font used in Technical Drawing, Questions
    By huygen in forum AutoCAD General
    Last Post: 20th Jan 2009, 02:15 am
  4. New: Technical Drawing Display Mode
    By Antisthenes in forum Rhino
    Last Post: 26th Feb 2007, 07:17 pm
  5. Technical Drawing Resources?
    By potatoshop in forum Catch All
    Last Post: 2nd Sep 2004, 05:17 pm
