Newbie question - how to modify existing code
Jay Tree
Hi,
I would like to move the decimal place in the coordinates 3 places to the left to convert from mm to m - e.g divide by 1000 - in the following code, for both X value and Y value. Have tried reading tutorials, but doesn't seem to work. Any help appreciated (e.g. divide the numbers that result from $(rtos,$(index,0,$(getvar,lastpoint)),2,2) in the following):
^C^C_id;\_-mtext;@;_h;$M=$(*,.25,$(getvar,ltscale));@1
Many thanks.
I have moved your thread to the AutoCAD LT Forum.
I do not believe AutoCAD LT can use any LISP. Looks like you are working on creating a Button Macro.
It also helps to use Code Tags.
[NOPARSE]
Your Code Here[/NOPARSE]
Your Code Here
Edited by SLW210
Corrected Information
Look at this example divide by 10 just add it in sequence.
$(/,$(getvar,viewsize),10))
I know I had a run diesel form command line it may be at home or else would test.
tested
X=$(rtos, $(/,$(getvar,viewsize),1000.0) ,2,2)
Run diesel from command line
(defun C:DIESEL ( / dsl )
 (while (/= dsl "M=")
   (setq dsl (strcat "M=" (getstring T "\nDIESEL: ")))
   (princ (menucmd dsl))
Edited by BIGAL
Hi,
I should have said that I'm pasting this into the macro field when creating a custom command in autocad LT (CUI). It seems to work fine. There is something else I would like to modify about it though:
The leader takes the default arrow style and size, is there a way to specify this in the code (I want circle with origin shown and size about 50) or to point it to a custom style within the dimstyles?
My directors are not currently sure if they want mms or metres, so lets run with the original code:
Many thanks.
Unfortunately there is no way to bypass the leader dialogue in LT, and dialogues can't be navigated with a script or macro, there is no commandline alternative.
Ok, thanks.
One more question. In LT on Mac, is there a way to access this custom command from the command line? E.g. like the usual commands PL, RECTANG, DI, etc.
Many thanks in advance.
If you mean your new macro, then I doubt it, I don't know anything about LT for MAC except it has quite a bit less functionality than LT, and in the windows LT version you cannot run a macro from the command line.
